ok that is entirely normal
that is your moulion heater, it is ment for two things
a. it keeps your seals soft and plyable
and b. it controls hot air entry to the unit when you open the door
it offsets the heat barrier with the door open,
that is what stops humidity from building up oin the machine
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Samsung RS2630WW Side by Side
Everything thing works great other than it stopped cooling this summer. It is only 3-4 years old...
(More)
Everything thing works great other than it stopped cooling this summer. It is only 3-4 years old model number RS2630WW manufactured 01/05. What parts should I try to replace first to get it running again? Any advise would be great. thank you Thomas
Samsung RS2630WW compressor not working, took apart and reassambled. Compressor worked for a short...
(More)
Samsung RS2630WW compressor not working, took apart and reassambled. Compressor worked for a short time then stopped again.
Samsung RS2630ww, stoped working. The green light on the electronic panel that indicates ice size...
(More)
Samsung RS2630ww, stoped working. The green light on the electronic panel that indicates ice size is flashing. The interior light for fridge and freezer are working but no cooling is taking place. We have had senors replaced in last 90 days which worked for a while. No noticable ice build up in freezer. We had a tech. come out and replace the circut borad and that did nothing. He claimed power was coming into the board but again this did not change a thing.
Our Samsung RS2630WW is making a squeaking sound. Specifically, I know it is the fan due to the fact...
(More)
Our Samsung RS2630WW is making a squeaking sound. Specifically, I know it is the fan due to the fact that I put a little bit of WD40 of the fan bearing and the squeak went away. Now it is making the sound again. Can you provide me instructions on how to replacing the fan motor.
