Question about Toshiba Satellite A35-S159 Notebook
A35 internal modem does not work
The internal modem switch does not light or recognize a signal. Is there a simple solution other than buying an external card ?
  • oldzinner Dec 29, 2007
    Could not find an appropiate key combination either in the manuel nor on the internet. Tried downloading the driver from Toshiba too but no luck. Thank you for your suggestions
  • oldzinner Dec 31, 2007
    Just installed a new PCMCIA card and evidently the on/off switch is not working so I cannot view available networks.
    Can anyone tell me if that is fixable without sending it back to Toshiba ?
This is a bad contact between the MB and Modem pins. U should open the wireless cover, find the modem and put a piece of paper between the modem card and the bezel to press the modem conection forward the MB. Beware to not damage the MB, wireless card and others devices.
This problem is usual in A35. BLOODToshiba....
Posted on Mar 01, 2008
  • 188 Answers
There may also be a key combination on your keyboard to enable/disable it. check for that first.
If that doesn't do it then i would reinstall the wireless driver from for your model and see if that helps.
Most wireless issues are software not hardware but if none of that does it the easiest thing is to buy a PC card.
Posted on Dec 28, 2007
DS240WB worked fine but seems now not recognizing signal and fails to turn on
The reason why your monitor might not be recognizing a signal is because the graphics card in your pc might not be correctly plugged into a pci slot or your internal graphics may have a short somewhere. If the monitor turns completely off after it cycles Then it might be an internal problem with the backlighting in your monitor screen
Dec 07, 2013 | DoubleSight DS-240WB Monitor
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
I have a Motorola SB 5120 modem the P/C light is always flashing .At time I can't get on Wi-Fi from my I Phone or my desk in my sons room, and other time i can.What is going on or do I need another...
The flashing lights (espicially the Internet light) are normal, they indicate activity (Power, LAN, Broadband, Internet).
Some modems suffer from signal interference from other wireless devices in your home and neighbourhood.
Sometimes the problem may be a signal deadspot in your home to do with unseen metal, pipes, wiring or some other aspect of the buildings architecture.
If your modem has a detachable aerial that crews and unscrews, then it might be possilble to buy a larger more powerful booster aerial for it (take the old aerial to the store with you to ensure compatibilty of the screw fitting) that will give you a better signal.
The modem does not have to be sited near a phone socket. Consider resiting the modem to a good central point where everyone gets a good signal, by buying and using Male to Female power cord extensions and Modem cable extensions.
Ensure that your internet connection is enctypted with a private network key and protected by a password, so that neighbours cannot pirate your internet connection and thus use up your bandwidth and slow down or degrade your signal.
I hope this helps.
Aug 25, 2011 | Arris SURFboard SB5120 Modem
My Toshiba Satelite a35-s159 can not connect to the internet unless its plugged into the wireless router or the modem
I had the same issue with the one I had. It was kind of a problem getting the WIFI to turn on. Consult your user manual or a quick google search to get the directions on how to turn on your WIFI. I don't remember if it has a switch on the front or not.
May 03, 2011 | Toshiba Satellite A35-S159 Notebook
I have a DHG536C Cable modem from Comcast Does is have an internal router so I can use a simple Eithernet switch or hup to connect 2 computers or do I need to use an external router?
The DHG536C is a pure cable modem. You will have to purchase a router to establish a network with the two computers. Alternatively you could connect one PC to the modem and have a peer to peer LAN network between the two pcs. The PC connected to the cable modem will need to be on all the time. You will need a wireless or a LAN card for each of the 2 computers.
If you wnat to buy a separate router you can select something from this site.
Dec 06, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Turn signals don't work but hazard and brake lights do.
Check your fuses. There is probably a separate fuse for turn signals.
Sep 02, 2010 | Ford Expedition Cars & Trucks
Where can I buy a new battry fo my labtop Toshiba A35-S1592
You can buy new batteries at the below link
and also
Jul 02, 2010 | Toshiba Satellite A35-S1592 Notebook
I need to install drivers for a35-s159.The Toshiba support page no longer supports this model.I need the modem and Ethernet drivers according to my hardware mngr
Wow, I can't believe they removed it from their support page. bummer.
You can try a simple Windows Update.
It should detect the missing drivers.
Let me know if it doesn't.
Jun 15, 2009 | Toshiba Satellite A35-S159 Notebook
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
My pc won't connect to the internet
It is the MAC address that needs to be scrubbed from the modem.
power off the desktop, power off the modem, unplug the data cable from the modem, unplug the POWER connection to the modem.
Connect power to modem, let it reset
Connect data cable to Modem
power on computer
Modem should now connect & work with desktop.
Each time you switch between systems, you may have to do this. More than enough to make me buy a router. =)
Please rate the post. =)
Jul 15, 2008 | Arris Touchstone 450a (CM450) Modem
Toshiba Satellite A35-S159 Notebook Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
