Question about Kodak EasyShare C875 Digital Camera
Shutter will not open all the way
My son dropped the camera and now the shutter will not open and the flash will not work
    Scholar:
  • 110 Answers
Sadly, it's not worth repairing.
Cheaper to replace it.
Posted on Jan 19, 2008
My sons kodak easyshare cx6230 only takes black/blank images. Screen works, but all photos taken are black. Suggestions please?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 06, 2011 | Kodak EasyShare CX6230 Digital Camera
LCD monitor is black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Sep 07, 2009 | Canon PowerShot SD890 IS Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Jun 02, 2009 | Nikon D300 Body Only Digital Camera
Flash doesn't work
don't drop a D80. wrap the fabric clipped onto the camera (say for hanging around your neck, which is a bad idea because of heat.) around your wrist two to three times, EVERY time you use it.
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter stays open-battery sign flashes but they are full..
This could be one of a number of problems, but first check the battery contacts are clean. These cameras rely on an elecrtic motor to drive the mirror and prime the shutter. The extra current drawn may cause the voltage to drop if the battery contacts are dirty.
Another possibility is a shutter fault, either the shutter has a sticky deposit or there is an electrical problem. Last time I had one like this I found a crack in the solder connection to the shutter.
Putting a new battery meants the camera will reset to a default setting. This means the shutter will be instructed to fire and the mirror return to it's initial position.
Jan 17, 2009 | Canon EOS Elan 7e with 28-80 lens 35mm...
Nikon Coolpix L16
i recently bought my cool pix l16 camera and when i took a pic my flash lamp kept blinking red and when i pressed the flash button my camera wouldnt flash
Jun 19, 2008 | Nikon Coolpix L11 Digital Camera
Casio exilim camera dropped and now doesnot work
you are going to have to send it in to the repairs dept. Their phone number is listed on their internet site under support and then "contact us"
Apr 18, 2007 | Casio Exilim EX-S500 Digital Camera
Lens problem
You might as well replace the camera in this case.
Nov 23, 2017 | Fuji FinePix A101 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
65 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
