Question about Goodman GDS80904BNA Open Flame Heater
No model number...
I'm not able to find the model number of my heater unit. I suspect the brand name is Goodman since the blower motor was branded Goodman. Where are the most likely places to find the model number?
  • lrschumacher Dec 28, 2007
    I found the label about mid-way under, but not directly, the burners. The middle numbers are not ledgible, but I should be able to get them with a little more research. Thanks!
  • 288 Answers
If this is a split system, look on the side of the furnace, no luck? remove the front panel. look for a little plate or sticker label inside there somewhere. If you are in California, there is a Goodman (A.K.A.) Janitrol, in Ontario CA. They may be able to help. (sorry don't remember phone #)
Posted on Dec 28, 2007
I need to find replacement parts for a Magic Chef propane furnace model EG6E80. How can I cross reference them with other brands?
good luck, what parts do u need, most of them can be re placed with other furnace name brands, like ignitor, blower motor, gas valve, pressure switch, ignitor board, transformer, ventor motor, they have replacement for all those parts, remember most companies use the same parts
Dec 16, 2015 | Heating & Cooling
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
Feb 26, 2014 | Emerson Lennox Ducane Armstrong Furnace...
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
Need instruction manual
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ``
Feb 05, 2012 | Black & Decker Garden
I have an Amana new AC for 2 years. The problem I have is that the outside fan unit is running but the inside unit in the attic does not run. what could be the problem?
All Amana and most other brands have a five year parts warranty, without the model number I would have to say either the thermostat, control wiring which sends a signal to the G terminal may not be working or the blower motor is bad or jammed up.
Aug 22, 2011 | Goodman Heating & Cooling
Do you know where i can buy or get a gas blower tube for my ''Ruud Achiever Self-Contained 10 SEER Package Gas/Electric Unit''
Rheem and Ruud are the same equipment, so look on line for a supplier of either brand, they just have the first number of the model number that is different.
What do you mean, when you say, gas blower tube?
heat exchanger, inducer draft motor?
Give me a shout back and let me know.
Paul Gibson
Apr 06, 2010 | Heating & Cooling
Blower will not shut off
That has to be in the board OR you might have the thermostat set to manual instead of auto. If you suspect the board remove the red wire from the motor to the board and see if the fan quits.
Jan 09, 2010 | Goodman GMS90703BXA Heater
Goodman furnace I think
Ok, a flashing 3 on a Goodman control board usually means that the pressure switch is tripping. A few things will cause this. One being a restriction in the exhaust or combustion air inlet. The second could indicate a faulty inducer blower motor and the third would be a blocked or bad pressure switch.
With the front cover off and door switch taped down, Have a helper turn the thermostat up to 75. You will be watching the circuit board for flashing lights and in a few seconds the inducer motor (the small fan hooked to the exhaust) will start. If this does not happen, we either have a bad circuit board or blower motor. If the fan starts rotating, inspect the hoses going to the small circular pressure switch. Sometimes they may get either water or debris in the hose and not allow the switch to sense pressure. If the hoses look OK, the igniter will glow an orange color and you will see this if you look thru the small viewing port. IF no glow, you could have a bad pressure switch, a bad ignition relay (found on the circuit board) or a bad igniter. OK so if the igniter glows, a few seconds later the gas valve should click open and send gas to the burners. The orange will turn to blue. If this does not happen, you have either a bad gas valve or bad circuit board. Finally if you get flame but it will not stay lit more than a few seconds, you may have a restriction in the burner gas train, a bad gas valve, a dirty or bad flame sensor or not enough gas pressure.
Knowing the sequence of operation will give you the needed information to talk with a service technician and cut down on diagnostic costs.
Try looking on the back of the furnace access panel for both model number and a diagnostic schematic. This will confirm what the flashing 3 code means for your unit.
Sorry, without knowing the model number, this is the best I can do for you. Good Luck!
Oct 28, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
110 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
