Question about Microwave Ovens
My microwave start button doesn't push in to start my microwave
The microwave start button doesn't always activate the microwave.  i need to roll my finger around and around the button until finally it activates.  it sometimes takes a couple minutes!  it sometimes starts easily, but it isn't always at the same spot on the round button.
  • 2 more comments
  • vanc Dec 27, 2007
    it is a samsung MW5698W  1000W, 120V
  • Anonymous Dec 29, 2007
    yes, I have the exact same problem with the Samsung MW5698W I have!
    start button doesn't push in to start my microwave. i have to push it some time for a minute !! some other time it start after one or two pushes. Seems to me that it get easier when the microwave was just used.
  • vanc Jan 18, 2008
    sorry- it is a button starter.  i suppose underneath the membrane could be worn out, but who knows.
  • Anonymous Mar 30, 2014
    RECENTLY WHEN TURNING ON FOR 2 MINUTES IT DOES NOT ALWAYS FINISH - IT JUST TURNS OFF
  • Microwave Ovens Master
  • 9,098 Answers
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
It's most likely that the keypad is worn out or possibly you have a flaky door switch.
We have full details, critical safety, disassembly, and troubleshooting info (as well as door switch testing info) at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually order Samsung parts (either the keypad / membrane switch or control panel with keypad) from http://www.samsungparts.com but that model number is not showing up, so you may have to call or e-mail them through their site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
  • William Miller
    William Miller Jan 20, 2008
    This appears to be a very old or very new model. I'm only getting spotty information about it.
    Is that a Canadian model?
    Can you post a photo of the control panel area?
    If it uses a plastic start button, there will be a switch (same type as a door switch) that the button activates. That switch would need to be replaced.
    As per my previous reply:
    link to our site in our listing here on FixYa:http://tinyurl.com/yzjozk
  • William Miller
    William Miller Jan 26, 2008
    You gave me a rating before I was fully finished....
    Here you go:
    replaced.
Lg microwave is stuck on message that says "push start or power level" but the buttons don't do anything. how to reset?
Usually, if you push the Stop/Clear button once or twice that will reset the panel. Barring that, unplugging it will almost always work :)
Dec 12, 2016 | LG Microwave Ovens
GE microwave light turns on when START buton is pushed and all the push buttons work but no heat, no sound and turn table does not turn. Any suggestions?
You might have a bad door switch, open thermal protector, or the latch mechanism is not activating the switches properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Dec 03, 2016 | GE Microwave Ovens
Door latch problem - doesn't always respond well
You will have to take the unit apart and see the reason. Could be a warn button or a bent part.
Dec 31, 2012 | GE Profile PEM31DMBB Black 1-cu-ft...
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
LG LRMP1270ST microwave is just over a year old. I put food in it, pushed "Add Minute" button and the timer comes on, the unit clicks and it doesn't come to 'life'. The timer does...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;;'
Jun 06, 2011 | Microwave Ovens
Hotpoint RVM1435 when I push start button will not start unit?
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Hotpoint RVM1435 Microwave Oven
Buttons are hard to push, always gives me a
Hi, no need to trash this unit. you can repair this and, its quite easy. the touch pad(key pad) is faulty and, you can purchase the replacement pad, via the link provided below. the instruction will be shipped with the part if you order it from the site. you will need to remove the units cover and, the control panel will be exposed. just replace the bad with the new.
Click here to purchase a new Touch key pay.
Jun 18, 2009 | Sanyo EM-N107 600 Watts Microwave Oven
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Microwave Ovens Logo
231 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
