Kenmore bottom freezer type refrigerator freezes vegetables...About a year ago the 'thermostat' was replaced because it was not cooling enough. Now it cools too much. I tried a work-around of turning the freezer temp down but then that gets too warm it doesn't keep ice cream frozen. How do I keep it from freezing vegetables?
Make sure freezer fan is working. This fan moves cold air from the freezer to the refrigerator. If it's not turning, the freezer will get too cold and the refrigerator will not get cold enough. The fan is usually located behind an access plate in the freezer compartment. Listen and see if you can hear it running. If not, remove the access plate and look at the fan. If it's not turning, you will need to replace the fan motor.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 62232 / 62234 / 62239
Crisper drawer for Kenmore Coldspot refrigerator model 106.53634300 Drawer part number probably...
(More)
Crisper drawer for Kenmore Coldspot refrigerator model 106.53634300 Drawer part number probably 1021812
what would cause a tempered glass refrigerator shelf to shatter when the fridge is turned off and...
(More)
what would cause a tempered glass refrigerator shelf to shatter when the fridge is turned off and there is nothing in the fridge?
Last night I came home to find water all over the floor under my fridge, a bottom freezer kenmore....
(More)
Last night I came home to find water all over the floor under my fridge, a bottom freezer kenmore. The whole thing was iced over inside, and the door partially open. I cleaned it up and closed the door. This afternoon I came back to find water all over the floor again, the freezer ice-bound, and water running out of the icemaker. The icemaker stopped making ice about a year ago, although it sometimes makes noises like it is making ice. Right now, there are ice cubes in the freezer, so it must have started to work again. I pulled the plug connecting the icemaker to the back of the freezer, and set the arm to stop ice.
Vegetables freeze in the winter and I don't know which way to turn the knob on the back of the...
(More)
Vegetables freeze in the winter and I don't know which way to turn the knob on the back of the fridge side to make it less cold. This is a Kenmore freezer on the bottom. Thanks.
Every time we close the top refrigerator, the bottom freezer pops open. As of the past two...
(More)
Every time we close the top refrigerator, the bottom freezer pops open. As of the past two nights, I have woken up with it open and the refrigerator turned itself off at the outlet.
