Question about Microsoft Office Outlook 2003 for PC
Broadband connection problem
When I look under network connections in the control panel there is no existing broadband connection. My modem is connected using USB. How do I set up a connection to use an ethernet connection? I need this to set up my wireless.
    Problem Solver:
  • 25 Answers
Best way to buy:
Usb Ethernet Adapter.
Otherwise, in that case it need Usb cable drivers to be installed in PC..... then u have to make share this Usb network connection(in network neighbourhood........network connection).
parrallel cat5 or cat6 cable should connect u'r PC to Router.
Posted on Dec 28, 2007
The Internet LED is red when there is no Internet connection
Unplug router for a minute or so and re connect also check if the computer is even recognizing the router in control panel under network conections
Jul 09, 2012 | NETGEAR CONSUMER Netgear Dgn2200m Wireless...
Tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 | Computers & Internet
I can't connect to the internet via broadband
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
hope this helps
Jun 06, 2011 | ASUS P5KPL-AM/PS Motherboard
I am using windows XP in my Toshiba laptop sattellie Series. I am unable to make any new connection to connect to Internet.
That is because the L300 does not support XP.
If you reinstall Vista, all will be well again.
XP is no longer supported even by Microsoft as it is over 10 years old and now obsolete.
Hope that helps.
Jan 23, 2011 | Toshiba Satellite Pro L300 Notebook
Dataone broadband siemens adsl c2110 modem driver
Am I correct in asking you whether you are using a bsnl broadband....???? If so you don't need modem drivers. All you have to do is configure a broadband connection from your network connection wizard with your username and password. Good Luck
Jan 08, 2011 | Computers & Internet
Does it need a modem or works on it's own ??
It doesn't need a separate modem; it replaces a modem in your home network. If it's properly connected to the phone line, and you have an internet service provider (ISP) supplying you with a broadband connection, and the PC is connected to the router, then it should all work fine.
If it isn't all working fine, the most likely problem is either that the wires aren't connected in the right places, or that the PC's internet connection isn't set up properly (e.g. if you changed from dial-up with a modem to broadband with a router).
If you have recently changed from dialup to Broadband, and you're running Windows, use the Network Connections wizard to set up the internet connection. In Windows XP you can do it this way:
1) click on Start
2) move the mouse to Settings
3) click on Control Panel
4) double click on Network Connections
5) click on File
6) click on New Connection Wizard
7) follow the instructions.
Your ISP should have sent you a CD-ROM to help you to connect, so insert the CD when prompted by the New Connection Wizard.
Sometimes you can just insert the CD into the computer and you'll be prompted to do everything necessary to connect to the internet. BT, for example, do it this way.
Oct 09, 2010 | Trendnet Wireless Home Router TEW651BR
I just brought a dell 10' netbook and i have dial up phone service so how can i get the internet on my netbook with dial up service?
Here is the internet setup info for that netbook from Dell's website ...
Setting up Your Internet Connection To connect to the Internet, you need a modem or network connection and an Internet Service provider (ISP).
To set up an Internet connection with a provided ISP desktop shortcut:
  1. Save and close any open files, and exit any open programs.
  2. Double-click the ISP icon on the Microsoft® Windows® desktop.
  3. Follow the instructions on the screen to complete the setup.
note.gif NOTE: Have your ISP information ready. If you do not have an ISP, the Connect to the Internet wizard can help you obtain one.
If you do not have an ISP icon on your desktop or if you want to set up an Internet connection with a different ISP:
Windows Vista®
  2. Click Start interne3.jpg ® Control Panel® Network and Internet.
  3. Under Network and Sharing Center, click Connect to the Internet.
The Connect to the Internet window appears.
  1. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect:
    • Choose Broadband if you will use a DSL modem, cable TV modem, or satellite modem.
    • Choose Wireless if you will use a wireless connection through a WLAN card.
    • Choose Dial-up if you will use a dial-up modem or ISDN (Integrated Services Digital Network).
note.gif NOTE: If you do not know which type of connection to select, click Help me choose or contact your ISP.
  1. Follow the instructions on the screen and use the setup information provided by your ISP to complete the setup.
Windows® XP
  2. Click Start interne6.jpg ® Control Panel® Network and Internet Connections.
  3. Click Set up or change your Internet connection.
  4. Click Setup. New Connection Wizard window appears.
  5. Click Next. Choose Connect to the Internet and click Next.
  6. Click Set up my connection manually and click Next.
  7. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect.
And here is the link to where the info was found...
http://support.dell.com/support/edocs/systems/xlob/dtg/en/internea.htm#wp1012333
and another with more info on that netbook ..
http://support.dell.com/support/edocs/systems/xlob/dtg/en/index.htm
Apr 06, 2010 | Dell Inspiron Mini 10v Netbook Computer
How I make a call on the huawei EG162g usb modem?
assuming that u r a professional n using a dialup broadband connection..
install itz driver (that usually provided with a cd or download frm the internet)..connect the modem..wait and verify if the device is detected..
now..open start menu->settings->control panel->network connections->new connection wizard->click 'connect to the internet'->next->setup my connection manually->next->connect using a broadband connection that requires a user name and connection->next->provide 'isp name'->next->give 'user name and password'->next->finish..
hope itz ready..
for supervision contact ur system admin/vendor....
Oct 30, 2009 | Computers & Internet
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Microsoft Office Outlook 2003 for PC Logo
203 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
