Question about JVC AV-56WP30 56" Rear Projection Television
I have picture but no sound
I originally had my JVC hooked up to a home theater system and had my internal speakers on the tv turned off. Now I have moved the tv into another room and have no audio because the internal speakers are turned off. How do i turn the speakers back on?
  • viper0515 Dec 27, 2007
    there is no audio menu, and the speakers were believed to be disconnected from the inside
  • viper0515 Dec 28, 2007
    well i tried all of these but there is no actual setting in the menu that allows u to doa ny of these things, my model is a AV-56wp30 56 in.
  • 143 Answers
Go to menue then audio then scroll down till you can get to the option that lets you change bass tremble then you will see an option that says internal speakers off on this will fix your problem
Posted on Dec 27, 2007
  • marco amezcua
    marco amezcua Dec 27, 2007
    make sure that your set is in ant a mode then look for menue thenadvance fetures then audio
    Problem Solver:
  • 16 Answers
Go into the audio menue to turn speakers back on
  • 234cataract Dec 27, 2007
    look for a speaker switch on the back. if they were disconnected from inside good luck. you will just have to look for disconnected wires.
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
When playing DVD all the audio is clear expcept words spoken by actors and is is buffled. How do I fix?
Make sure your Center speaker is enabled, defined to the system and working according to the manual.
See pages 18 and 19.
Then look at DVD Preferences on Page 37 and run those speaker tests and adjustments.
Mar 08, 2011 | JVC TH-C6 System
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
Would like to listen to tv through the 5.1 speakers and don't know how to hook them up to do so, please help
You can run red and white from tv out to in on reciever, or optical out tfrom tv to in on reciever or digital coax audio from tv out to in on reciever, depending on which connections you have. then you would put your reciever on aux to hear tv through surround system. Also if you have a cable box or satellite box you can run the audio from that box to the input on surround system.
Hope this helps.
May 05, 2009 | JVC TH-G30 Theater System
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Nov 12, 2008 | iLO Televison & Video
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
How do i switch a jvc home theater system from pal to ntsc. model # rx-dv3sl
How do I switch a JVC home theater system from pal to NTSC.
Please e-mail this information to (shamarmec@yahoo.com)
Best Regards
Sharie
Dec 18, 2007 | JVC THC3 Home Theater System System
Ilo tv
i dont think that the ilo has a sound output port:(
Oct 17, 2007 | iLO V27DMBX Television
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
JVC AV-56WP30 56" Rear Projection Television Logo
240 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
