F3 means your oven temperature sensor is open. you will need to get it replaced. hope this helps.
This can also mean the control board has a problem. Check that the temperature sensor is about 1080 ohms at room temperature. If it is, it probably needs a board rebuild. Here are some other common problems for this whirlpool board. http://www.news.fixyourboard.com/boards/news_4452900.html
Reach out to us at 512-355-1108 or [email protected]
SOURCE: my kitchen aid oven has error codes f3 e1 what do
Hello there:
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
Now if it is just a f-3 and nothing else3
f 3
Open oven
temperature sensor or thermal fuse
Replace oven
SOURCE: kitchenaid oven has error codes f3 and e1 what
f-3 e-1 is a bad oven sensor. its a rob inside the oven a little smaller than a pencil you remove two screws and slowly pull it into the oven and disconect the wire harness. remember to remove power first good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: what does error E1 F3 mean kenmore range
Hi....F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
SOURCE: fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
