Question about RCA F32650 32" TV
RCA TV I HAVE A F32650 RCA 32" TV THE HIGH VOLTAGE COMES AND GOES FROM IT I STILL HAVE SOUND BUT NO PICTURE THEN IT COMES BACK ON AND IT PLAYS OKAY IF I HIT THE TV WITH MY HAND IT WILL COME BACK ON.
  • 373 Answers
Look for bad solder connections on the solder side of the board: You have to take board out of the plastic and slides out. Look around the high voltage transformer pin connections and large transistor associated with it and all connections associated with it too. Use magnifying glass. Could be hard to see. You could also shotgun the whole section by just soldering all associated connections. Look for burned connections also.
Posted on Dec 29, 2007
My television comes on and plays great for about 10 minutes then the picture goes out but you can still hear sound,then you'll cut it off for another 10 minutes and turn it on and it plays great again for...
a good indication of one or more electrolitic capacitors failing or a cathode ray tube ie picture tube with a heat related internal short shutting down the high voltage system if this is a rear projection tv time to call a certified electronic tech
Dec 17, 2014 | Televison & Video
My RCA big screen plays for about half a movie and picture dims then shuts off. Sound still works. I shut off for a few minutes picture comes back on and shuts off again after few minutes.
These units are famous for loose connections around the high voltage transformer and also bad capacitors in the power supply. The deflection PCB has to be removed to fix this problem. You probably would need to have a repair shop check it out for you. Thanks
Oct 29, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA tv when plugged in comes on and right back off
IF THE PICTURE IS TALLER THEN THE NORMAL SIZE IT MAY BE THE VOLTAGE REGULATOR. LETTING THE 130V POWER SUPPLY GO TOO HIGH.
Mar 20, 2009 | RCA 27V514T 27" TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
Cricket sound from tv
it sound like a fly back or horz output problem . This is a high voltage problem. very common in rca tvs the cost to fix it depends on size 85 dollars up to 250 dollars
thanks DOCTOR VIDEO
Apr 25, 2008 | RCA F27TF700 27" TV
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
52 in RCA
The T.V. has no lamp, it has 3 guns red,blue,& green. Unplug the lead that goes to the high voltage splitter(make sure t.v. is unplug). Then turn the t.v. back on if you hear the H.V. lead making a hissing sound continuously most likely the h.v. block needs to be replaced. Follow the lead from the flyback to the h.v. splitter, this will be the lead that unplugs at the splitter.
Oct 11, 2007 | RCA P52926 52" Rear Projection Television
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA F32650 32" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
