Question about Samsung SC-D6550 Duocam Mini DV Digital Camcorder
Just a question about power for this camera
Can this camera be operated from the supplied a/c charger or is it required to have a battery?
    Problem Solver:
  • 4 Answers
You can use the AC charger just fine.
Posted on Feb 07, 2008
I recharged my camera using 5 volts nokia charger to my camera which has 3.5 volts battery only then what happened is whenever my camera on it will suddenly off while the lens/zoom is extended.. pls help.
The camera requires power to extend or retract the lens. The indicator of a low battery is your only notification that a loss of power will stop all functions of the camera. The camera should only be charged or operated with the manufacturers recommended power supply. The increased voltage as well as incorrect Amperage may have adverse reactions, such as you are now experiencing.
Dec 16, 2012 | Cameras
Hi I have the vivitar vivicam 8025 dont have my manual want to know how to charge my battery
First off, you can download a PDF version of the manual from the manufacturer at:
If you don't have a PDF viewer, you can download one from: (just click download under the free version)
For your convenience I've pasted the relevant information about charging the batteries from the above manual:
Please charge the battery as below 2 methods: A. Charge with USB cable Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED willbe off when charge full.
B. Charge with supplied charger Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
Please leave feedback if this was helpful. Thanks.
Apr 11, 2011 | Vivitar Cameras
I have the vivatar vivicam8025, how do you recharge it with the cable, I can't find the manual
Charge lithium battery
Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED will be off when charge full.
Mar 02, 2011 | Vivitar ViviCam 8025 Digital Camera
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
Need power supply
Do you have a battery charger? If so, on mine I found a power-in little hole next to the battery power pins in the camera battery compartment. I also found the same type of power-in hole (like the ones found on a cell phone) on my battery charger. A double ended cord came with my camera. Maybe you have one, too. I plugged one end into the camera and the other end into the battery charger. Then I plugged the battery charger into an AC house outlet. This gave power to my camera. I am sure that you can find this type of double ended power cord on line or at a store.
May 16, 2009 | Panasonic AG-195 VHS Analog Camcorder
I cannot find the ac cable for my d100 camcorder. can I get a ne
Missing Camera-Charger cable:
I had this problem, many places don't have the connector to even make one. The camera requires the full voltage from this wire to download video. But, I found the 99cent store had a CIDCO caller ID unit that used a power supply with the same size connector on the power supply. so... $2 and cut the two connectors off and twisted the ends together and voila.. problem solved. Camera to battery charger worked. The battery must be in the charger for some reason, but the camara connects. It dosen't light up during this proscess though, and it took almost a minute to do it.
The Caller Id is actually pretty good. so reconnect the wires back and you'll have $2 worth of caller ID. ( service must be active from your service provider ), but every telephone can have a display.
Apr 07, 2009 | Panasonic VDR-D100 DVD Camcorder
Won't run on batteries
the connectivity with the battery terminal is a problem .open n check there may be some loose connection on the points where ur battery inlets supply connection on the main board of ur camera.
Dec 17, 2008 | JVC Video Cameras
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Aug 27, 2008 | Xantrex Technology Xantrex Freedom Xmic...
Sony camera turning itself off...
You can't use regular alkaline batteries in this camera. Alkaline batteries only supply 1.5 volts. The camera uses 2 in series for a total of 3.0 volts from alkaline. However, the camera requires 4.2 volts to operate correctly. This camera has high power requirements, so you'll need high end lithium or nickel hydride batteries that can supply the higher voltage and current this camera requires. It's a power hog, and regular alkaline batteries are too weak to run it. The menus will work on alkaline, but once you try to turn the camera on in capture mode to take a shot, the current requirements to operate the camera motor, LCD, zoom, memory stick, etc, all it once is too great a draw for alkaline to handle. Either use the external power supply, or get Lithium batteries. Make sure the batteries you get are 2.4 volts and not 1.5 volts. Get the ones with the highest current rating you can find.
Aug 31, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Samsung SC-D6550 Duocam Mini DV Digital Camcorder Logo
41 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
