Question about Kenwood KDC-MP205 CD Player
NO memory in kenwood kdc-mp205
My kenwood player does not remeber where I left of on my audio cd or mp3 after I turn it off and then on again.
  • mixedupmike1 Aug 06, 2008
    If my starter is the problem how can i fix that?
  • just1 Dec 23, 2008
    my stereo does not remember my setting when i turn the key switch off.
  • 36 Answers
Check your wiring in your vehicle to make sure that the yellow wire from the stereo gets "constant" power. It it what keeps your stereo's memory, and powers the audio amp in the stereo. If this wire is loosing power when you shut the key off in your car, you will loose all of your settings...bass, treble, tuner, clock, and also where you left off on your CD.
Posted on Dec 31, 2007
Itdddddddddd
Posted on Mar 01, 2008
Do you have any problems with starting your engine? When you turn the ignition key, your starter draws a lot of current from the battery (it may be even 700Amps) - so you can say, that you "short" your battery. When you send the current to starter, the voltage from the yellow wire disappears. If you have troubles with starting your engine (bad candles or something else), then you will draw the current to a starter trying to start your engine for too long time and your receiver will lose all the settings you stored in it. Your units internal capacitors are able to maintain the set settings only few seconds after the voltage from the yellow wire disappears, so if are rotating the starter for more than few seconds, you will lose all your settings.
Kenwood how to connect
You need a stereo mini to RCA cable to connect the laptop's headphone audio jack to the Kenwood. Here is an example of one below. They are very common and available at just about any electronics store for a few bucks.
http://www.amazon.com/Gemini-PH62089-Stereo-Mini-Male-RCA-Male/dp/B0001GAOE0
The Kenwood receiver should have a number of red and white "RCA" audio connectors on the back.
Just connect the RCA portion of the cable to a spare input. They should be clearly marked on the back of the unit and color coded (red for right channel and white for left channel). But it really doesn't matter if you mix the right and left up, it will still make sound.
EX:
Most receivers will have inputs that are labeled "CD" or "Aux" that you can connect any audio source to.
If you connect your laptop or an MP3 player to the audio input connections labeled "CD" behind the Kenwood receiver, you can listen to the device by selecting the CD as the source.
It is really easy!
May 04, 2014 | Kenwood VR-305
How Do i Turn on The LOUD option on my kenwood KDC-MP205
Unless you turned it off, Kenwood radios automatically have the loud turned on when the radio is first powered up.
Jul 10, 2011 | Kenwood KDC-MP205 CD Player
I dont understand how to play mp3 player on my kenwood cd player.I have the cord to hook it up to my kenwood radio but i dont know how to get the mp3 to play.
Just plug the cord into the front of the cd player where it says "AUX" and then plug the other end of the cord into the headphone / line out jack on any ipod or mp3 player then select "AUX" instead of CD and the sound will come through the system
Jun 02, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
I cant hook up my mp3 player up to my kenwood cd player!!! i bought the hook up too and i still cant
select the auxillary input display and push the control knob left or right until you see portable, then you should be able to play your mp3 device
Mar 28, 2011 | Kenwood KDC-MP235 CD Player
How i can attach mp3 or memory card with my kenwood player
Hi.
If the Kenwood is compatible with USB memory adapter, then you will have an USB port on the front side of the player, just aside the CD slot.
If the stereo is MP3 compatible, that does not mean that the unit is compatible with USB devices.
If the Kenwood is MP3 but not USB compatible, you can play MP3 files burning them onto a CD, then playing the MP3 CD in the CD player.
Regards.
May 25, 2010 | Kenwood KDC-MP228 CD Player
I HAVE NO DISPLAY ON MY KENWOOD CAR CD PLAYER
you probably have bad solder connections on a series of surface mount resistors on the front left side of the deck.
Feb 12, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood KDC-MP205 CD Player Logo
275 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
