Home | Shredders | Royal 85X 10 Sheet Shr...
Shredders
Problem for Shredders
Generic problem for all Shredders
Royal 85X 10 Sheet Shredder
By dadmizer999 on Dec 27, 2007
It just stopped working , It powers on fine & the light goes off when the basket is opened . Is there a sensor somewhere , I can't find my manual anywhere .
Best Solution
posted on Mar 02, 2008
Helpful)
fellowesrep
Rank: Guru
Rating: 87%, 143 votes
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
Was this helpful?
Yes
No
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
CX12 motor runs but shredder wheel doesn't turn
Answer
I need to replace the on off swithch for my fellowes shredder Powershred 220. How much and how do I... (More)
Answer
the main drive gear on my universal UNV-38082 medium duty paper shredder is stripped. i need a... (More)
Answer
How do I clear out a paper jam around the blades?
Answer
How do I clean out a paper jam around the blades?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shredders:
Top Shredder Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
