Question about Sony VAIO PCV-V100G (PCVV100GKIT1) PC Desktop
Emachine computer
Hi i have an emachine computer flate screen the light on he monotor flashes every 3 sec. the monotor will not come on .everything ealse dose it just dosnt show anything on the screen its just black.please help
2 Suggested Answers
  • 1003 Answers
SOURCE: Black Screen
Posted on Jan 16, 2008
Whoa. I'm not sure why, but this just worked. As soon as I hit F2 repeatedly, the machine restarted without a problem. Woooohooooo!
Posted on Sep 28, 2008
0 characters
1 Points
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
When i turn my computer on it shuts off immediately and the blue light on the power button flashes until i unplug from the wall. i have emachines t 6522
Looks ugly. I'm not a tech person, but this is certainly no software problem because there's no time for the BIOS to load. (The BIOS is a little program that is run as soon as you turn your PC on and checks that everything is OK before loading the operative system, i.e Windows, Linux, etc)
Hmm... might be an electrical problem. How "immediately" does it turn off? Can you see any words on the screen? It could be many things, like a bad mother board or hard drive. If you can't see any words on the screen, *********** board might be burnt.
Jun 28, 2011 | E-Machines eMachines Desktop PC
What type of flate screen monitor can we use with a e machine t3604. We have tried a MAG innobision and it does not work. Model
Any flat panel screen should work. if the screen has DVI input you'll need a DVI to VGA adapter you can get flat panel screens that have VGA connection or both.
Aug 06, 2010 | eMachines T3604 PC Desktop
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
Nov 07, 2009 | E-Machines eMachines Desktop PC
Emachine t3104
For doing a system recovery on E-machine you have to press F11 number of times at the very first boot screen then follow the procedure, and it will restore your computer back to the factory settings.
This option is available in new computers only. (2-3 years old)
Jan 12, 2009 | E-Machines (T3104) PC Desktop
My computer wont start
it shows power supply gone bad, check it
Oct 28, 2008 | Dell OptiPlex GX260 PC Desktop
Sony VAIO PCV-V100G (PCVV100GKIT1) PC Desktop Logo
18 people viewed this question
Top Sony PC Desktops Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Thomas
Michael Thomas
Are you a Sony PC Desktop Expert? Answer questions, earn points and help others
