Question about Sylvania DVC850C DVD Player/VCR
Dvd/vcr combination What would cause the player to have a black vertical line down the center of the tv when playing a dvd? It is not on the tv itself.
  • 35 Answers
An easy first step is to check and make sure that you don't have any other rf interference. make sure that all radios, laptops, pcs, routers, etc.. .are not nearby. they can cause interference. A second idea requires knowing how you have it connected and what other types of equipment you have connected to the tv itself
Posted on Dec 27, 2007
MY toshiba tv MW27F11C only shows a white line when turned on
Hello uuka,
You have vertical collapse. This is most often caused by a defective vertical output integrated circuit, an open dropping resistor which feeds the supply voltage to the I.C., one or more defective electrolytic capacitors in the vertical circuit or something as simple as bad solder connections. The latter will usually manifest itself as an intermittent failure. Less likely, but stilla possibility is a defective yoke, but this a rare.
Unless you are handy with a soldering iron and have some experience this is definitely something I suggest that you refer to a qualified technician. Depending on the actual cure for the problem, this would typically be under $100 in my shop, but we are in a small town and prices are cheap. I would definitely recommend a repair on this since it can not be replaced. They don't make a TV/DVD/VCR combination any longer and the picture quality on these Toshiba/Orion combos has been very good over time.
Hope this helped and don't forget to rate...
The Wing Guy
Apr 29, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Only has a line through center of screen
Problem started as a simple cold solder joint. Now the connection has either burnt to the point of not making any connection at all, or the vertical output has gone out due to the stress. As far as the dvd player goes. Sounds like the microprocessor is heating up and going bad. Nothing can be done other than replacing the whole unit.Should be able to order it from Toshiba.
Oct 16, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
When turned on only gets a straight line of color in middle of screen
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
Jun 07, 2008 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
Samsung tv - switch to play a dvd player
All you should have to do is hit the TV/Video button on your remote. It also could be named AUX, or or INPUT. What this does is tells the tv to switch to the input you have the DVD player hooked up to. Otherwise it will keep drafting a signal off of your cable line.
May 31, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
hey lindalu if you and i put our tv's together we might have one whole working tv/vcr/dvd combo that plays in color! Seriously though, i feel your pain. RCA i'm not impressed.
Feb 17, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Sylvania DVC850C DVD Player/VCR Logo
88 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
