Question about JVC DR-M1 DVD Recorder
JVC XVM565BK 3-Disc DVD Player
My dvd player says it has its parental lock "on" . i am required to enter a code. i have tried several codes that it could be, to no avail. do i have any options?
thanks
TRY LOOKING FOR FACTORY DEFAULTS IN OWNER'S MANUAL TO RESET TO
Posted on Feb 02, 2008
  • JBCOL Feb 02, 2008
    PARENTAL LOCK displays
    When no disc is inserted or a DVD VIDEO disc is
    stopped, pressing the ENTER button while holding
    down the SHIFT button accesses the PARENTAL LOCK
    display in which you can set the level for limiting
    playback.
    See page 40 OF OWNER'S MANUAL for detailed information.
    ENSURE NO DISC IS LOADED. When you enter the wrong password more than 3 times
    The cursor moves to [EXIT] automatically and
    CURSOR
    5/° does not work.
    • If you forget your password in step 2:
    Enter “8888.”
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
My DVD player is locked, the display shows a red key.
Hi, This sounds like a parental lock issue. Try going into the set up menu and press the down key choosing custom by pressing enter (this is in the user manual page 20 - 22) then go down and select parental. If you know your parental control password code then enter it, if not the reset code is 4737 you will then need to create a new 4 digit code,There are 9 levels to choose from 1 - 8 and all, all being the selection that removes the parental lock. Hope this helps. James
Apr 21, 2010 | Sanyo DVW-7100A DVD Player/VCR
Cannot remember my parental control number is there an overide
try this:
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Apr 12, 2010 | Sony PlayStation 2 (PS2) Console
JVC XV-M555 DVD player has the parental control set somehow. Need to know how to disable the parental control on this DVD player
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Jan 01, 2010 | JVC XV-M555 Multi-disc DVD Player
Parental lock on cant eject dvd
1 try un plug and plug back in
2 if not work enter menu and look for settings and look for parental lock or ratings most codes are 1234 / 0000 / 5555 or 8888 but if you changed code i will not know
3 open dvd and look for rubber belt and cog then turn it until dvd draw opens ( UN PLUG FIRST )
hope this helps
MERRY CHRISTMAS
Dec 12, 2009 | JVC XV-N322 DVD Player
Need master pass code to a ps2 to play movies
There is no master pass code, but there is a code to reset the parental settings. It's important to note that 7444 is NOT the password. You have to hit SELECT when asked for the password. That is where you enter 7444 to clear the code.
Oct 14, 2009 | Sony PlayStation 2 (PS2) Console
The parental lock comes on on certain dvd movies.(JVC xv-n322s)
Well Girls and Boys that is to stop naughty people accessing media your parents prefer you not to see. Discuss the matter with them and don't try to subvert your parents concern for your mental healt by involving us in your naughtiness. These DVD's have codes applied and parents who paid for them know what sequence to enter on the remote to unlock them, so try asking them if its suitable for you and have THEM do it
Sep 19, 2009 | JVC XV-N322 DVD Player
Went to play dvd and i have to do a password how do i change it
You have parental lock, this can be quite bothersome with trying to find the right code. Here is the procedure to reset the parental lock code: 1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup. 2. When the screen asks for the code, press the SELECT button, then enter in the code "7444". 3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off". 4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Jun 11, 2009 | Sony PlayStation 2 Slimline Console
Zenith DVD Parental Lock
Try power on the player with no disk in the drive. Press "PAUSE" on the remote. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display). Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) . Press "PAUSE" on the remote. Power the player off and then back on
Feb 17, 2008 | Zenith DVC2200 DVD Player
JVC DR-M1 DVD Recorder Logo
129 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
