Question about JVC KD-G430 CD Player
Everything resets after power off
I have the constant power hooked up properly.. But after my jeep is turned off everything resets... Is it possible the ground isnt connected good enough? This is the 2nd vehicle I have had it in and it did it in the first one..
  • 1,512 Answers
You should always wire constant power to the battery. This allows you to guarantee constant power. Don't trust anything else and you will always have success. TO THE BATTERY!!
Posted on Dec 28, 2007
  • Graeme Ross
    Graeme Ross Dec 28, 2007
    You should always wire constant power to the battery. This allows you to guarantee constant power. Don't trust anything else and you will always have success. TO THE BATTERY!! oh yer... a good constant ground connection is also required. measure the chassis of the radio against the vehicle earth- any stray volts here. Check all earthing from the battery on through
I hooked up my pioneer dehx8600bh car stereo everything works perfectly except when I turn my head lights on the stereo loses power and factory reset every thing
Not sure what kind of car you have but,,, just for the heck of it, when you turn on your lights , try turning your interior dimmer all the way up. If the radio works again, then you have it powered from the wrong wire in the dash. It needs to go to a constant hot (12V) and Accy/ignition (12V) and not to a lighting wire which would power the back lighting of a factory radio.
Jun 29, 2015 | Pioneer Car Audio & Video
I have just installed a JVC KDR406 head unit in my car, the thing turns on but only for 3 secs then shuts down, everything is hooked up fine, just don't have power for long, turns on when i push eject or...
This is normally caused when the unit does not recognize constant voltage. To bench test radio combine both red and yellow and run to constant voltage to see if it happens to turn on. If i does, most likely your RED connection was not connected properly.
Jul 27, 2014 | Car Audio & Video
New dual marine stereo worked the day I hooked it up the following day I've got power but no sound Any possible solutions?
Make sure everything is properly connected.Try other speakers also check if there is a reset button at the back of the face plate. If it still has no sound it could be the output IC is blown .
Apr 23, 2014 | Car Audio & Video
Hi, I had a start problem with my celica. tried to turn the car over and a constant clicking sound was made, however all lights were on and the radio was working.. thought possible starter problem,...
The problem is that your battery is extremely low. The repeated clicking sound is your starter relay trying to engage, then releasing again when the starter takes the remaining voltage available to try to turn. When the relay disengages, the starter can no longer take any voltage at all, so the relay again engages and the process starts over. This results in "CLICK, CLICK, CLICK, CLICK...." There simply is not enough power available to operate both the relay and the starter.
Your alarm system doesn't have enough voltage to function properly. It "thinks" that someone is trying to steal your car or is messing with your battery cables. It doesn't know the difference between low voltage from a dead battery and low voltage from somebody disconnecting wires. It is simply responding to the low voltage condition as it is designed to do. Fix the voltage problem and you will fix your security system. No need to reset anything.
Jump-start the car or replace the battery and get your charging system checked to make sure everything is functioning properly. It is possible that the battery is good but you have a bad alternator and the battery is low because it is not being charged.
Aug 17, 2011 | Toyota Celica Cars & Trucks
When the ignition is turned off and turned on again the clock keeps reseting to 00.00
Sounds like you don't have the 12v constant hooked up. There is two 12v sources, one is ignition, and the other is constant. All it's for is keeping the settings. The ignition wire from radio is for turning radio on when car is on or in acc setting. Pull radio make sure everything is wired properly. U can't wiring information on the web using radio brand and model number.
May 05, 2011 | JVC KD-AVX33 CD Player
I hooked everything up but it only turns on constantly i cant get it to turn of with the rest off the car
you need to know which wire is your constant (+) supply and which is the switcheable (+) Connect the yellow wire from the deck to the constant + and the red from the deck to the switcheable + power as the red is you on off and the yellow is your memory. Sounds like you almost have it right-just need to find a switcheable power supply for the red .
Dec 11, 2010 | Pioneer AVHP3200BT Car Video Player
I recently wired a eonon e1091 into a 2007 silverado classic. i used a scosche wiring harness that allows me to keep my chimes. everything works fine but when i turn the truck off, theres still power...
It's called delayed acc. power. It should shut off as soon as you open the door. Unless the red stereo wire is hooked up to constant power. You may need to check with a test light.
Oct 31, 2010 | Car Audio & Video
My new cd player wont turn off in my 1999 Honda Civic
The problem is you have the two wires hooked together. It's back feeding. One has to be hooked to key power. and one to all time power.
Jul 10, 2010 | 1999 Honda Civic
I installed a jvc kd-g140 in a 2003 ford ranger i get everything to work but when i turn the truck back off i loose all the memory of the stations and bass settings what do i need to do to fix this problem...
Your memory wire isn't hooked up correctly. Your memory wire is possibly hooked up to your ignition wire. Take them apart, and find a constant power supply to hook up to your memory wire.
May 19, 2010 | JVC MXKC45J
JVC KD-G430 CD Player Logo
69 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
