Question about Creative Labs Zen MicroPhoto MP3 Player
Switch on and recovery mode comes up
Hi
when i turn on my zen a recovery mode is comeing up with the options of
  1. clean up
  2. format all
  3. reload firmware
  4. reboot
i tryed all of these as nothing was working. so i turned it of and back on again and the same thing happend
please help
cheers
chris
  • 1 more comment
  • Anonymous Dec 29, 2007
    only get moe assistance- will not boot up
  • panuco98 Apr 01, 2008
    Ok If the problem is the hard disk. How I going to replace it? And also how I going to open the case and which tool I going to use for this task?
  • confusedme Dec 24, 2008
    wtf does this mean???
I get a Solution ID 16737? Anybody know what that error code means?
Posted on May 29, 2008
Replace the HD, then flash the firmware.
Posted on Jan 30, 2008
Recovery mode Creative Zen v1 21 03 0 3 1 clean up format All reload firmware Docked
Jun 22, 2011 | Computers & Internet
Credit card size zen
Hi Lil
Sounds like you have tried all the obvious. The unit may have a terminal hardware problem or an unrecoverable firmware problem. I suggest that you return the unit to a dealer and see if there support guys can produce a cure for you. I am looking for any other things that you may try. Will post any for you soon
regards
Graeme
Feb 17, 2008 | Creative Labs Zen Digital Media Player
My creative zen micophoto will not boot up what do
Hi.
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
  1. Press on the Menu/Back button on your player, and select System, and then Reset.To Format or Clean Up Zen Vision:M Detach the Zen Vision:M player from your PC , and ensure that the unit is off.If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears: * Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)* Format All (Formats the players hard disk - Note: all contents will be lost)* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)* Reboot (Reboots the device)
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot
Good Luck^^
Nov 02, 2009 | Audio Players & Recorders
Creative zen m vision won't start up,
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
I have a Creative Zen Sleek (20G) andit will not reboot as it comes up with "Hard disk problem" Could you let me know how to get this repaired
this is a recovery for the zen player
Detach your ZEN 20GB from the PC and ensure that it is turned off.
  1. Connect the power supply to the player (Optional).
  2. Slide the Power switch towards the Power On icon zen_20gb_reset2.jpg and hold it there while inserting one end of a paper clip into the Reset hole underneath the player. zen_20gb_reset1.jpg Warning: Take care to insert the paper clip into the Reset hole and NOT the Microphone
  3. The Rescue Mode screen appears when ZEN turns on.
    1. Remove the paper clip and release the power button.
    2. The following options will be displayed:
    1. Clean Up
    Scans the player and removes invalid links from its music library.
    Does not affect music files themselves.
    Format (All) Caution! Erases all content!
    Save a copy of your player's content before formatting.
    Reload OS/ Firmware Caution! Erases your player's firmware.
    DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
    Reboot Reboots the device.
  • Aug 20, 2008 | Audio Players & Recorders
    Stuck in recovery mode--would love to avoid buying a new mp3
    I had the same problem as your and it stopped working yesterday. After search for helps and now it is working again after I reloaded the firmware. But unfortunately everything is gone. You have to reload your musics again. You can try this out: 1) go to creative labs website to download the "Recovery Tool". 2) at Recovery Mode of your zen there are options: Clean Up, Format All, Reload Firmware, and Reboot. Try out Clean Up first if it still not working then try to Format All. After that try the Reload Firmware. After you done the Reload Firmware. 3) Shut down your Zen and try to connect it to your computer. Now your Zen will automaticlly power On and computer will recognize it as a drive. 4) Open the Recovery Tool you have downloaded at creative labs website. This tool will detect your Zen and follow it's instructions: It works with my windows Vista. Well, it works for me, I think it will work for your too. Good Luck!
    May God bless.
    Jul 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Recovery Mode
    Detach your player from the PC if it is connected, and turn off the player.
    If the player stops responding, you can reset the player. To reset the player, gently
    insert a thin object into the Reset hole located below the power switch.
    2. Press and hold the Play button while powering on your player.
    3. When the player displays the Creative logo, release the Play button.
    It will display the following options:
    Clean Up
    Format (All)
    Reload OS/ Firmware
    Dec 28, 2007 | Creative Labs ZEN V Plus MP3 Player
    Hard disk prob
    hard disk is bad.
    can you format?
    1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
    2. Connect the power supply to the player.
    3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
    underneath your player, beside the data/power connector. Keep on holding the
    Play/Pause button while you release the Reset button. The Rescue Mode screen will
    then appear.
    4. After the recovery mode has started, release the Play/Pause button
    It will display the following options.
    Clean Up Scans the player and removes invalid links from its music library.
    Dec 04, 2007 | Creative Labs Zen Touch MP3 Player
    Problems with turning on
    Sounds like it may be the index in your Music Library. Try going into Recovery Mode the routine way; remove battery(are they charged and good?), hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart/Reboot. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
    May 28, 2006 | Creative Labs Zen Micro MP3 Player
    Creative Labs Zen MicroPhoto MP3 Player Logo
    455 people viewed this question
    Top Creative Labs Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Mohamed Ismail
    Mohamed Ismail
    Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
