- if you open top panel,there is a motor relay,there are two in there a motor relay and a heat relay,the motor relay is the one farthest to the right and i believe there are two blue wires going to the motor relay and two red ones going to the heat relay,change out the motor relay and you should be ok,let me know how you make out
Nov 11, 2009
- you can swap the motor relay and the heat relay they are the same to see if this is your problem,next time send full model number
kenmore dryer 11072970990, works fine for about one cycle then it stops. I have to wait for at least...
(More)
kenmore dryer 11072970990, works fine for about one cycle then it stops. I have to wait for at least 20 minuts to restart. What could be the problem.
