Washer fills with water, but when it moves on to the cycle, the motor is moving, but it sounds like something is stopping it from moving, and when i put it on spin only it drains the water and works perfectly
under the agitator there is a bell coupling with splines on it. it could be that this piece is worn and not meshing with the transmission to properly move it.
Was this helpful?
Yes
No
Popular Solutions for GE WBSE3120B Top Load Washer
I own a GE WBSE3120 top loading washing machine. It fills up fine, proceeds through the wash cycle...
(More)
I own a GE WBSE3120 top loading washing machine. It fills up fine, proceeds through the wash cycle ok and when it comes time to drain and spin, it does not work. It just makes a noise. Potential source of trouble?
GE Washing Machine WBSE3120B1WW -when I first start the washing cycle you will start to hear a loud...
(More)
GE Washing Machine WBSE3120B1WW -when I first start the washing cycle you will start to hear a loud clucking noise and the motion of the tub becomes very slow and then it stops all togehter this will repeat untile the wash is complete can you help diagnose?
how do i remove relay from ge washer it has slots on each side and does not want to come it seem...
(More)
how do i remove relay from ge washer it has slots on each side and does not want to come it seem like it will break
Our top loading washing machine in condo near the ocean has a loud grinding sound -- like sand has...
(More)
Our top loading washing machine in condo near the ocean has a loud grinding sound -- like sand has gotten into the gears (parts of the motor mechanism. Lots of tenants use our condo during the summer. Solution?
