Question about Kenmore Elite 45986 Front Load Washer
KENMORE HE5T NO Hot Water
Just bought new washer and get no hot water when washing. Cold line works. Checked to see if hot water valve open. Still no hot water. Laundry tray gets hot water as well as whole house. None for washer.
  • kevin hinchley Aug 14, 2012
    hot water valve sounds to be the problem
    Master:
  • 619 Answers
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Posted on Jan 10, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Kenmore eco cycle front load washer. error E70 displays and stops washer. What does E70 mean?
You should check the model number of the washer. If the model number starts 417, then the washer was made by Frigidaire. In that case, the E70 error indicates that cold water is not being detected at the washer inlet sensor.
In some cases, this could be due to connecting the hot water line to the cold water inlet (and the cold water to the hot water inlet). Make sure that the cold water shut-off valve is open. Try swapping the water hoses (close the shut-off valves first). Try new hoses; some anti-flood hoses will restrict the water flow if they detect damage. Thus you won't have sufficient water coming into the washer. (You can check this yourself. Turn off the shut-off valves. Disconnect the hoses from the washer and put the ends into a bucket. Then open the shut-off valves and check the water flow.) While you have the hoses off, check for debris in the inlet filters.
If the hoses are fine, you probably have a problem with the washer's inlet valve or the reed switch that measures incoming water. The inlet valve should be replaced if you find that only hot water enters the washer.
I hope this helps. Please add a comment with the model number of your washer for more information. It will be on the inside of the door opening (probably at the top).
Sep 30, 2013 | Maytag EPIC MFW9700S Front Load Washer
Cold water overflows
your hot water is filter by your water heater...need a fill valve, part#3952164, sugg. retail $30. your valve is jammed open.
Jun 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Mar 05, 2009 | Kenmore Washing Machines
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
436 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
