Question about Frigidaire FDE336RE Dryer
Not stopping My Frigidaire FDE336RES2 will not stop. Its been doing it for the last 2 weeks. I set on a specific time just like I always have but it does not stop. Keeps going and going. I have to keep careful watch and stop it myself.
  • 625 Answers
One or more of the timer cams is stuck. if the timer is electronic then the triac used for the motor contactor is gated closed. change the board. mechanical timer - change the timer.
Posted on Dec 28, 2007
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
Truck suddenly stopped running like battery was dead. Got a jump nut only ran for 1-2 seconds then stopped again
I have a 2003 Chevy Avalanche 1500 Z71 4X4. What you describe happened to me (6) times last week. #1, I replaced the ignition switch, $32.00. The issue happened again last night and recorded the code P1514 (Throttle Body performance condition). #2, I cleaned the MAF (mass airflow sensor) and the throttle body. These parts require specific cleaners, which can be purchased at any parts store. Truck runs like new. Best regards, Mike Pyne
Jun 24, 2010 | 2003 Chevrolet Avalanche
Dryer vibrating with overheating smell
The vibrating is usually the blower wheel not being balanced or worn and not spinning, therefore it does not blow enough air and therefore the system overheats-----and so, the smell. Some models need to be serviced from the rear, others need to have the front face removed to access the blower wheel assembly. The blower wheel is approx. $25 part but you need the skill to access and replace it properly. Goodluck, Macgivor
Dec 27, 2009 | Frigidaire Dryers
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
My frigidaire heavy duty dryer model number FDE336RES2, starts to squeak once it turns on. It will continue to do this until it warms up then it stops. How do I fix this?
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does? SOME PICTURES
Sep 07, 2009 | Frigidaire FDE336RE Dryer
Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
Sep 03, 2009 | Frigidaire Dryers
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
My LG LRH-880 HDD/DVD recorder sometimes stops recording by itself, before the end of the programming and even if there is enough disk space left.
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
Sep 13, 2008 | LG Televison & Video
sounds like the starting device for the compressor clicking on/off not always starting, hopefully under 5 years old cause sounds like a bad compressor(full 5 yr warr on on that)
Mar 14, 2008 | Frigidaire FRS26R4C Side by Side...
Dryers Logo
163 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
