Question about Epson Stylus Photo R300 InkJet Printer
Epson stylus photo r300 printer
Behind the ink cartridge, there is two yellow bands and one long clear plastic strip (band). wich rests horizontally behind ink cartridge. The clear plastic strip is broken! What can I do to replace this..and is it fixable??
  • Epson Master
  • 1,879 Answers
Those parts are not user-replaceable
call the vendor - check your warranty status
check this link just in case : http://www.epson.com/loyalty
Posted on Jan 03, 2008
How do I change the ink cartridge on my Epson R300 photo printer
You can find the manual here:
http://files.support.epson.com/pdf/r300__/r300__u1.pdf
on page 90 - 91 there is a description how to replace the ink cartridges.
Mar 11, 2011 | Epson Stylus Photo R300 InkJet Printer
How to install new cartridge
Make sure the printer is on and not printing. Have a new cartridge handy, as this installation should be done in one session.
Note if the "cartridge is low" or the "cartridge is empty" light is activated on the printer and follow the specific instructions carefully in the document below for each situation.
See "Removing and Installing Ink Cartridges" in the following document:
Epson Stylus Photo R300 - Removing and Installing Cartridges
Mar 01, 2010 | Epson Stylus Photo R300 InkJet Printer
Printouts have horizontal streaks
Make sure you do the cleaning maitenance,
and must use Original Epson Ink Cartridge.
Good Luck.
Dec 23, 2009 | Epson Stylus Photo R300 InkJet Printer
How do you change ink cartridgesfor the epson r300
Press Ink button;
Select Ink Cartridge Replacement
Press OK
changer cartridge
then press OK
And wait for initializing
Dec 18, 2009 | Epson Stylus Photo R300 InkJet Printer
Changing the ink cartidge on Epson R300
The strip should have a yellow tab to pull on.. Check on the bottom of the cartidge and see if you can see a thin piece of plastic covering the pins. If not then the cartidge did not have the protective covering and could possibly have dried out.. Return it to the store and get a replaement.
Jun 17, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 is broken
remove the colored not detected then clean the chips then take it back again and turn of the power of printer then on again then see again...thanks...
May 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
Epson Stylus Pro 9600 horizontal banding problem
the banding is a result of clogged head. I had the same problem and fixed it with many cleanings.
Jul 12, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson photo r300
the ink cartridge is on the carriage, as you lift the lid of the printer you should see the cartridges to the right.
May 28, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
