Question about Balance CM2019 19" LCD Monitor
Line All of a sudden, my monitor has a thin black line dividing the screen. the picture is fine, but with a line down the midde. I have tried rebooting, no good. Anyone know how to fix this? It is a Balance CM2019 19"
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Have sound on westinghouse 42 in tv but no picture..just vertical thin lines..thia happened suddenly have hd box rebooted cable. tv will not turn off or on but has power
check it against another computer if the same result then its faulty
is your graphics card a standalone if so that could be the problem
but i am assuming it built in then option 1
Sep 18, 2014 | Westinghouse Tx-42f430s 42" LCD HDTV...
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
I have a thin black line across my screen half way down
You don't say whether it is a LCD monitor or a CRT one.
CRT Trinitron tubes have two thin black lines, one at about 1/3 height, one at about 2/3. This is normal and nothing to be worried about (sometimes one and more rarely both lines can't be seen).
LCD monitors should NOT have any black lines at all, and if they do it's probably a driver latch circuit gone bad -- and there's not much that can be done in practice, except replace the monitor.
Oct 24, 2009 | Soyo Computers & Internet
My AOC 5en CRT monitor have a horizontal line whole screen... how i fixed it?
this is called hline problem. only a thin line is seen in the screen and the screen is black. the cabinet needs to be opened then it needs slight setting from the picture tube to get the whole picture.
Sep 05, 2009 | AOC CT720G 17" CRT Monitor
The monitor goes on but no picture. when i turn
RAM problem. Fix the RAM properly in the RAM slot.
May 07, 2009 | Olevia LT26HVX 26 in. LCD Television
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Computer monitor screen stays black
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 26, 2008 | LG Flatron L1710S 17" LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Black horizontal line
The LC display is bad. The monitor will have to be replaced.
Jun 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
Balance CM2019 19" LCD Monitor Logo
55 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
