Avion AV-DVR100 DVD Recorder
Problem for Avion AV-DVR100 DVD Recorder
After initial setup
By sgilb1122 on Oct 15, 2009
After initial setup "xx channels found" press system menu to exit. Display indicated "blocked" and nothing will work. ??Help
Comments:
Oct 17, 2009
- There is no "Setup" button on the recorder or the remote!
Oct 17, 2009
- Some people may think I'm a kid but I'm 82. I bought this unit (cheap) from Geeks.com (as a refurb), to do the little recording I do rather than pay the cable co. $10 per month for their dvr. I would have thought the refurb unit wouldn't be sold in unusable condition. The manual does mention setting up access control but indicates it only acts on coded discs, not others. The setup on this unit doesn't get that far,it block every thing.
Oct 18, 2009
- It depends on what is considered helpful. You told me I had a problem to which there is no solution_that I am happy with. Anyway thanks, Sid
Best Solution
posted on Oct 18, 2009
Very Helpful)
rulds2008
Rank: Guru  Televisions & Videos  Expert
Rating: 86%, 1105 votes
Okay, here is the issue with this. If you trying to record CABLE TV they have a lock on all digital clear qam signals without there converter box this sounds like this is what is happening. So you need to connect a cable box from the output to the input of this and then from this to the tv put this on channel 3 and turn the cable box to the channel to be recorded.
Cable company purposely black digital signals nothing you can do.
Thanks and please click the accept button
Solution #2
posted on Oct 17, 2009
Not Rated)
njvinod
Rank: Wiz  Televisions & Videos  Expert
Rating: 85%, 390 votes
Are you a kid?
If so, your parents have activated the V-chip that comes with all TV's and allows them to block programs that they don't want you to see. The only way to get around it is to get the secret password. If you are an adult and have nobody else who could have set the V-chip, perhaps it was set at the factory (if you bought it new) or by a previous owner (if you bought it used)..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Solution #3
posted on Oct 15, 2009
Not Rated)
rylee_smith
Rating: 87%, 994 votes
Hi
Thanks for using FixYa. Try and reset your dvd recorder by turning it off and unplugging it for 4-5 hrs. This will reset the error, if not then follow this procedure to reset it---
  • Turn unit on,wait until finished starting up
  • Press SETUP
  • SETUP is Displayed on DVR100
  • Press Right Button
  • Press Down Button three times
  • Press Enter twice
  • Unit should revert to Factory Defaults.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Comments:
Oct 18, 2009
- Hi
Did you tried this follow the reset procedure i gave you in a previous post---
  • Press SETUP
  • Press Enter twice
Thanks
Rylee
Popular Solutions for Avion AV-DVR100 DVD Recorder
Questions and Unsolved Problems for Avion AV-DVR100 DVD Recorder
Do you recommend Avion AV-DVR100 DVD Recorder?
Answer
Answer
I just bought an Avion AV-DVR100 DVR. It seems pretty good except for one thing: the external a/v... (More)
Answer
can i use my avion dvr 100 without hooking up to the TV..to copy a dvd to a blank dvd? Also what... (More)
Answer
Does not communicating with the TV. When I put it on, it wiil just blink on TV and then disapear.
Answer
When a blank disc is inserted, the recorder flashes a message "disc error", it will play... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
