Question about Video Game Consoles & Games
REPLACEMENT BATTERY FOR R/C CAR
I OWN A COLUMBIA RED R/C RACE CAR THAT ONLY PERFORMED ONE TIME BEFORE THE BATTERY DIED EVEN AFTER TRYING TO CHARGE IT. I HAVE TRIED FOR SEVERAL MONTHS TO REPLACE THE BATTERY TO NO AVAIL. THE MODEL OF THE CAR IS RC-16MI. THE BATTERY WAS MADE IN CHINA---GO FIGURE---AND HAS 3 TERMINALS. IT IS A SEALED LEAD ACID BATTERY 12V 2.3Ah. ARE ONE OF YOU GURUS OR WIZARDS ABLE TO ASSIST ME?
  • 4 more comments
  • gramirez1988 Jan 17, 2008
    I have the same car a Mitsubishi Eclipse, also looking for a battery.
  • Anonymous Mar 02, 2008
    Same problem with my columbia rc car the battery will not charge and cannot find a replacement battery anywhere
  • harrytt Nov 12, 2008
    Man I have kind of the same problem, only I need a charger and not a battery, but for the same kind of battery?
  • ulises0521
    ulises0521 Sep 16, 2012
    i have the same car too a mitsubishi eclipse, looking for a battery, charger and remote control please i need it
  • streetergrap
    streetergrap Apr 30, 2013
    I may have found a replacement battery, I have the same problem, it is the Fast and Furious Green Model RC Car with a dead battery! I found this on eBay and am awaiting a reply from the commpany:http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
  • streetergrap
    The only problem I see is that this replacement battery does not have the wires connected so you may have to do some surgery on it and take the wires and connector piece from the old battery.
The 3rd wire coming off of the battery pack, the blue one, I have not discovered the purpose of. But the red and black control the power for the car. I've noticed that running power to the red and black will make the car function, but not in reverse. So I'm guessing the blue wire has something to do with a switch inside.please help,how rc car reverse without a third blue wire,thx.
Posted on May 14, 2011
I had a similar problem. But my battery worked for some time. All of the connections seem to be cheap and all of the battery connectors have taken corrosion damage over time. For 'zhustack', your charger is only supposed to have 2 prongs on it, not 3. The red and black wires on the battery pack are the positive and ground wires. That's what is is charged off of. The 3rd wire coming off of the battery pack, the blue one, I have not discovered the purpose of. But the red and black control the power for the car. I've noticed that running power to the red and black will make the car function, but not in reverse. So I'm guessing the blue wire has something to do with a switch inside.
Posted on Nov 11, 2010
I have a red Mitsubishi Eclipse but i am not looking for a battery,But i an looking for a charger. I need a new charger because mine has two prongs not three like supposed to.
Posted on Jun 08, 2008
When its charging it flashes green & red and won't take a charge
If it is a Makita battery charger it means the battery has died or has an internal fault, or is too hot.
Take it out of the charger, let the battery cool down if required and try again.
If both red and green lights are flashing, try a different battery.
It might be time for a replacement battery.
Mar 21, 2015 | Drills
Battery will stay charged
Have the battery charged and tested and then test the charging system. You should never run a car with a very dead battery. that will burn out the alternator.
Sep 14, 2013 | 1996 Buick Century
My camer will power up say battery low but shows to be full but goes off and will not come on and charge.
How old is the battery? Batteries do die with with time. Be sure to replace it with a manufactures battery, not an aftermarket one.
Nov 14, 2012 | Sanyo Vpc-t1496 14 Mp Digital Camera - Red
Check gages light came on. the gas gage read 20 mi to empty. turned it off then on again and read 107 mi to empty. the engine soon died in the middle of traffic. Is it the battery???
The battery is one possible problem. However, the alternator charges the battery, and if that goes bad, the check gauges light will go on, in particular, the charge light will go on (red in color).
This is actually a very common problem. If the alternator is bad, it can cause the car to lose voltage over time, 30 to 40 minutes after the light goes on, the car will die if operated for that period of time with a fully charged battery, even.
Aug 17, 2010 | 1999 Jeep Grand Cherokee
My watch is 8 months old and just stopped..the screen still displays the exact time and date that it died..but because it's digital if it was the battery the screen should have gone blank?!!
Best bet is to start by replacing the battery. At 8 months it'll be due for one soon anyway and a new battery may "reboot" it so it runs again. As a battery wears out it doesn't just stop, it may still maintain the display even though it stops keeping time. Also, new "e-ink" displays require no power to maintain the display 0 only to change it.
Apr 28, 2010 | Columbia Digital eBook Watch for Women
Inspiron 600m laptop flashes the red light at the bottom of screen as if it needs charged, but it is 100% charged and is not hot or anything. It flashed red three times then green. I powed down unplugged...
when you use battery power, does the laptop work or does the battery die right away try letting the battery die itself, like use the laptop till it dies then charge it up again
Apr 05, 2010 | Dell Inspiron 600M Notebook
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Battery not recognized
Have you adapter checkup also that its supplying constant
supply.
Apr 28, 2008 | Dell Inspiron™ 600M PC Notebook
Video Game Consoles & Games Logo
562 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
MegaByteMe
MegaByteMe
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
