Question about Nokia 7370 Cellular Phone
No speaker or ring Nokia 7370 7373
Nokia 7373 will not ring, or nothing on loudspeaker or speakerphone.
During a call, the handset volume is 10 and works fine. Also works with bluetooth headset and wired headphones.
But if anytime during a call or playing music, and is switched to speakerphone, nothing comes out, even with volume at 10.
I've reset the phone *#7780# and also updated with v5.5 for this phone.
What else can I check?
How can I check the phone amp N2101? What voltages should be when speakerphone is on? What other test points can I check? How can I check the speakers?
  • Anonymous Jan 03, 2008
    i have the same problem with my 7373 the loudspeaker just stopped working
  • sammer003 Jan 14, 2008
    I sent the phone away for service, to a place in Vancouver, B.C. Nokia service center would take weeks.
    They did it fast, and it works. I just sent them the phone, they mailed it back. Fast, relatively cheap, I thought.
    If anyone want the address, please email me.
  • 36 Answers
This problem is not cause by the software. The buzzer of the phone must be replaced with a new one. Go to the nearest Nokia Service Center or any cellphone repair shops you have that one on your area, or from where you bought the phone. This buzzer is the audio output for music, tones, etc. except for the calls, its a different speaer.
Please Rate Thanks!
Posted on Jan 14, 2008
How do I increase the external ringing volume on a
Adjust Volume
There are 5 levels (VOLUME 1 to VOLUME 5) to choose from for the earpiece or speakerphone volume
During a call: Press <up/down> to select volume 1-5.
The current setting is displayed. When you end the call, the setting will remain at the last selected level.
Sep 21, 2014 | Binatone Lifestyle 1910 Twin Cordless...
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
How do I turn on the speakerphone
From the Nokia 2680 manual:
"Loudspeaker
If available, you may select Loudsp. or Normal to use the loudspeaker or the earpiece of the phone during a call."
Does your phone definitely have speakerphone? It seems that it's an option, not standard on all of this model.
Aug 10, 2012 | Nokia 2680 Slide Cell Phone
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
Can only hear on speakerphone
This speakerphone is a separate speaker from the handset speaker, so if you can't hear through the handset and you have ensured that the volume in your profile is set up to max, then I would have to say there is something wrong with the handset speaker.
Hope this helps,
Bill
Sep 03, 2009 | RIM BlackBerry Pearl 8100
In my mobile there is no loudspeaker option in Nokia 6681
For volume and loudspeaker control increasing or decreasing the volume level when you have an active call or are listening to a sound, press left or right scroll, respectively. Sound applications use the loudspeaker by default.
To use the loudspeaker during a call, start a call, and press the button with the talking face icon and press again to return to earpiece.
If it does not work the speaker, or amp circuit is bad or there is a glitch in the firmware. Replacing the speaker is the only economically viable repair. If the amp circuit or firmware has malfunctioned a new phone is in order.
Jul 05, 2009 | Nokia 6681 Cellular Phone
I have a p910i ... how do i activate my loudspeaker while speaking on the phone
To activate the speaker:
  1. Activate the speaker during a call by selecting "More" > Speakerphone on.
  2. Deactivate the speaker by selecting "More" > Speakerphone off.
Dec 02, 2008 | Sony Ericsson P910i Cellular Phone
Speakerphone on nokia 6085
I have the same problem. I called ATT and they didn't know. The manual doesn't explain it either. This is one of those problems that seem to have fallen between the cracks. ...
May 10, 2008 | Nokia 6236i Cellular Phone
AT&T 926 Corded phone
check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Feb 13, 2008 | AT&T 962 Corded Phone (A21076)
Nokia 7370 Cellular Phone Logo
626 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
