Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Arch on top and bottom of screen
My Philips 55PW9363 55 inch rear projection TV has an arch along the bottom and the top of the screen. I adjusted the convergence and it helped with the colors but the arches are still there. When a news channel is on with the ticker running along the bottom you could really see the arch. It's also really noticeable at the top when the program description box is visible.How do I fix it?
  • 2 more comments
  • Anonymous Dec 28, 2007
    need to know how to replace ic ?
  • Richard Gorenflo
    Richard Gorenflo Jul 31, 2008
    rgflo64
    YesI have the same problem.
  • Anonymous Oct 10, 2008
    me too.
  • Anonymous Nov 11, 2008
    arch on top and bottom
  • Philips Master
  • 3,459 Answers
You may have a convergence problem.  Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors.  Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors,  etc. Everything you need to fix it yourself.
Posted on Nov 28, 2008
  • Philips Master
  • 5,138 Answers
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Posted on Jan 19, 2008
Rainbow arch across the bottom quarter of the tv. the arch is green
possibly magnetic interference check and see if there are any magnets such as a speaker magnet near the bottom of the tv - if so move it away from the tv this should eliminate the arch. could be at the back or the front
Jan 31, 2010 | Zenith R57W46 57" Rear Projection...
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
shaun
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergance with my pioneer projection screen tv
Your going to have to do it manaully if it does not converge automatically.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence on Projection screen
More than likely the repair company used cheap chips when they did the repair. The cheap ones fail real quick. Goto the site www.TvRepairKits.com. They have built a kit that you can do yourself. It includes name brand chips and a photo instuction guide.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arch on top and bottom of tv
You can try adjusting the convergence manually, but this is not a good symptom for your TV to have.
Look at this Quick Start Guide, p. 7:
http://www.p4c.philips.com/files/5/51mp392h_17/51mp392h_17_qsg_aen.pdf
Mar 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
Arches of words and top and bottom doubled with red words
Convergence mis-alignment = replace convergence amp IC's
Part # STK392-110 sub to upgrade STK394-160E. I use
Hitachi brand for no recalls.....................T.
Oct 31, 2007 | Philips 60PP9202 60" Rear Projection...
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
Red and Green Vertical Arches
CHECK ANY MAGNETIC MATERIALS ON THE CORNER OF THE TV.IT HAPPENS DUE TO MAGNETIC MATERIALS ONLY. SUPPOSE IF IT IS THERE KEEP AWAY FROM THE TV. AND THEN GO TO THE MENU OPTIONS AND SET AUTO DEGAUSSER ON.
Apr 23, 2007 | Philips 32PT8302 32" TV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
190 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
