Question about Panasonic PT-47WX49 47" Rear Projection Television
I see double on screen, red and green.can i adjust it plz let me know.
    Genius:
  • 1,694 Answers
Requires replacement of convergence IC's....STK392-110
Adjustments will not fix...................T.
Posted on Dec 29, 2007
I fix the red doubling by adjusting the red screen screw now the people are greenish. can someone help me. pt-56wx53g
turning the red Screen down even slightly will make the other two CRTs dominate over red. You may be able to turn the Green and the Blue down slightly to balance them back to what red is at. Turning the screens down too low will cause them to shut off if they get lower than the cut off point.
Sep 15, 2011 | Panasonic PT-56WX53 53" Rear Projection...
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
PANASONIC PT-46G40U CONVERGENCE PROBLEM HELP...
Have you checked the bias resistors for Exact Value. They normally change value when the stk's take a dive.
Dec 09, 2009 | Panasonic PT-46G40 46 in. Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence
When this happens it means the convergance Ic's have failed ( STK392-110's) they will need replacing then the cross hairs will move again
Feb 07, 2008 | Panasonic PT-56HX40 56" Rear Projection...
Panasonic Model No. PT-47WX42F
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Oct 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX41 yoke adjustments
go back and check them resistors....with a magnifier and be sure of the color codes...I bet one is way off. and get the manual out confirm each resistor u replaced and even remeasure it. dont mess with yokes or nothing on them tubes! its on the board....check for solder splash too on bottom or shorted pins on stks. if you must just make a big x on screen from corner to corner now cover red and blue tubes. the green should be in center of the x if not move the adjusting 2 magnets near yoke to center it it will have tabs sticking out u might have to move both. after you center adjust red and blue to green. good luck
Aug 15, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
you have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
thanks
scott
Aug 30, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
