Question about Dayton G73 Utility Heater
Too Warm I want to keep my garage at about 40 degrees.  At the lowest setting it stays at 54 degrees.  Is there a way to solve this?
  • GMAC12 Jan 09, 2008
    Did replacing the thermostat work??
  • 288 Answers
The thermostat may not be made to go lower than 50 degrees or so. A new one that can may need to be substituted. Go to the local appliance parts supplier. remove the old one and tell them what range you need.
Posted on Dec 28, 2007
My dehumidifier keeps turning off is hooked up to hose no water draining air filter is clean. model #ld450eal 45 pint
The most common problem is that the humidity extraction level is set to high. Set it to it's lowest setting. If you have an LED screen on your unit, the lowest setting will probably be 35%. Or in the case of no LED screen, Minimal will be the setting you want to use.
Since you're using a drain hose, I assume the unit is in the basement. If that's the case, the ambient air temperature at floor level, may be to cold for the unit to operate properly. Most dehumidifiers struggle at air temperatures between 40 and 60 degrees F. Try placing the unit up off the floor on something sturdy that can handle the weight (including a full tank of water) and the vibration during operation.
Hope this helped you trouble shoot and solve the problem.Please let me know. Thanks.
Jun 01, 2011 | LG Dehumidifiers
New Mr. Slim system just installed. Set to "Heat." Temp setting adjustment on the remote control will not go below 59 degrees. Is that factory setting? Set at 59 it keeps room at 70 degrees,...
I have a related concern. I put the Mr. Slim unit in my garage/workshop and most of the time need it just to keep the pipes from freezing. I'd like to set it at 45 or 50 degrees, but the lowest it allows is 59. I bought this to save energy, but it's forcing me to keep the room warmer that I'd like.
Dec 03, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have just aquired an pth5498 tv and want to place it in my garage/game room - what is the lowest tempature that it can be in before there is possible problems or damage when turning it on?
If you live in a cold weather area, I am in California, it should be in a place where the temperature is never under 40 degrees F.
You could blanket it or add insulation to protect it but if not practical understand it may react poorly to extreme low temperatures. I have a set here (projection) that when we have cold weather (it gets down to 35 degrees sometimes) does not want to turn on--I have to use the room heater to get it to work which is fine as my wife complains if the bedroom is too cold.
I hope this information helps you and if so rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH Steve in San Diego, Ca.
Aug 11, 2010 | Akai PTH5498 54" Rear Projection...
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70...
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Mean: 46.94
Standard deviation from grouped data: 15.40
Oct 23, 2009 | Microsoft Excel for PC
Refrigerator is Warm and Freezer is Cold
The hot air does have an effect on the system, but it should be cooling better than this. Your defrost system may have burned out. Look at the heaters first, then check the defrost timer. They both may need to be replaced. Call us for parts and we'll be sure to get the right ones out to you. Hope this helps! :>)! Ella
Sep 09, 2009 | Refrigerators
Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Apr 14, 2009 | Refrigerators
Fahrenheat fuh 54 b does not run long enough to get garage warm
have you checked what the operating amps are vs. the amps provided by the outlet. Sounds like you are trying to pull to much load and the machine probably has a saftey to where it shuts down bofore it buns itself up. Hope this helps. You have to be real careful about overloading circuts.
Dec 19, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Fridge cooling 54 degrees - freezer 38 degrees and 24 degrees
Will not be the defrost timer as they have a set cycle independant of the normal cycle...unless your fridge is eletronic. Did you stand the fridge up when shifting?
Dec 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dayton G73 Utility Heater Logo
112 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
