Question about Standard (CRT) Televisions
Lost code. RCR 311 w 2626 p
I need a code on my remote RCR 311 w 2626 p
0 characters
1 Points
I bought RCA or rcr311str remote for tv use.i have Sony tv of model kv- 2720 so how do I use this remote?
These are the set up codes for Sony TV with RCA RCR 311STR remote control.
10810, 11685
Jul 27, 2012 | Standard (CRT) Televisions
I can't find a remote for my Prima TV model#XT-2799. Help!!
Universal remote codes for Prima TV are:
1019 0165 0116 0167
Just note these codes, and buy a universal remote control, which have these setup codes in its code list.
If your TV asks for a five digit code, buy one RCA RCR 311STN model remote control. Five digit codes for this remote control, with Prima tV are:
10761, 10783, 10815, 10817
Jun 13, 2012 | Prima CV2011 TV
Ds19310 remote code
You are asking for universal remote codes for Sany I assumes, and posts this solution. Actually I didn't understand about your need. So I hereby send teh code list published by Sanyo. It doesn't contain any codes for TVs, at the email address you provided on your complaint post. Check and feel.
Five digit universal remote codes for Sanyo are:
10054, 10154, 10159, 11142 [codes with RCA RCR 312W universal remote control]
Three digit universal remote codes are:
004/ 013/ 049/ 108/ 110/ 180/ 209
four digit remote codes are:
0049 0097 0110 0004 0268 0012 0108 0180
Nov 26, 2011 | Sanyo DS19310 19" TV
What is rca remote code for sylvania model srt2232s
Four digit codes for Sylvania TV with RCA RCR 311W remote control are:
1003, 1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066, 1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1150, 1151, 1165, 1192, 1199, 1206
Five digit codes for Sylvania TV with RCA RCR4373N remote control are:
11864, 10054, 10030, 10171, 10096, 11271, 11314, 11394, 11963
Sep 29, 2011 | Sylvania SRT2232S 32" TV
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
What remote control goes with the rca truflat tv?
Just buy one RCA RCR 311B universal remote control. You will get all instrucions and setup codes along with it. The setup codes for this remote with RCA TV are.
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
gopakumarg43_34.jpgThis is the picture of RCA RCR 311B.
Aug 30, 2011 | RCA TruFlat 27F520T 27" TV
What are the codes for universal remote controls for a goodmans tv ?
Universal remote codes for Goddmans TV with RCA RCR 3273 are:-
1056, 1065
It is very difficult to get codes for your Goodmans TV. OK.
Jul 10, 2011 | Standard (CRT) Televisions
How can i get a remote for my ktv ?
Remote codes for KTV with RCA RCR 311S are:
1004, 1035, 1046, 1065, 1068, 1078, 1083, 1123, 1127
Just buy this model RCA remote control You will get instructions with it how to set it up. OK.
Jun 30, 2011 | Ktv Standard (CRT) Televisions
RCA universal remote won't program to my TruTech T2000-FT
There is only one code for Trutech and it is [1208]
This code is with RCA RCR 311B remote control. OK.
Jun 30, 2011 | TruTech T2000D TV
What universal remote is acceptable for a toshiba 19A21 tv?
You just buy an RCA Universal Remote Control
Mosel numbers are RCR 412BN / RCR 412SN / RCR 412SIN. All of these remotes have listed Toshiba codes to suite to wirk with it.
Codes are:-
11524, 10154, 10156, 11256, 11265, 10060
Direct Code Entry
Direct Code Entry lets you enter a code from the accompanying
code list for your brand of device. It's not as easy as the other
methods, but it's potentially the fastest method.
1. Manually turn on the device you
want to control
2. Find the Code List that came with
the remote. Locate the section for
the type of device you're trying to
program, and find your brand in
that section. Circle the codes for
your brand and keep them handy
3. Press and hold the device key you want to program (the
ON•OFF key comes on).
While you're holding down the device key, use your other
hand enter the first five-digit code for your brand in the
code list (the ON•OFF key goes off after the first digit).
4. When you've finished entering the five-digit code, keep
holding down the device key and look at the ON•OFF key.
Is the ON•OFF key on?
YES: You're done! You've programmed this device key.
NO, it blinked four times and turned off: You have
either entered a code number that is not in the code lists or
missed a step in the code entry procedure. Try step 3 again.
TIP: Each device key is associated with a type of device-the
TV is preset to search for TVs, SAT•CBL•DTC for satellite
receivers, cable boxes or digital TV converters, DVD for DVD
players, and VCR•AUX for VCRs and DVRs. To program a
device key for a different type of device, see the Changing a
Key's Device Type section.
The ON•OFF key serves as an indicator light during
programming, giving you feedback at each stage of the
Remember to enter the code for future reference in the box
provided in the Code Retrieval section of this manual.
If your brand isn't listed in the code list, use one of the Code
Search methods to program the remote control. (Refer to the
Auto and Manual Code Search methods.)
If you release the device key any time during the Direct Code
Entry procedure, the ON•OFF key blinks four times, and
the process is exited. The last programmed code under the
device key is retained.
Test the remote with the device to make sure the device
key is programmed with the correct code for maximum
functionality. If some features don't work, try a different code
in the list.
Nov 30, 2010 | Toshiba 19A21 19" TV
Standard (CRT) Televisions Logo
91 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
