Hello Sir !! Welcome To Fixya !!
To turn off beep sound its quite easy.Just follow the simple steps are you are done :
Go to MenuThen settings >ring styles > style detail > keypad volume.Bring keypad volume to zero and beep sound is gone.Enjoy !!IF this was help full please rate or token of appreciation will be esteemed.
Did you check whether the Caps Lock and the Keypad key is released? If the keypad key is enabled by using maybe the Fn key and one of the F key, some of your keys on your keyboard will be defined as to enter the little alternative characters on them. When it is enabled, you may be able to see a little light on your keyboard under an icon look like a keypad. Sometimes some keys may get stuck or not working so your password is changed when it is typed in. So you can clear the bottom of the keyboard a little bit by maybe put it up side down and maybe shake it a little bit (when turned off) or press those keys down and feel whether it is touching the bottom. When you press one key down you can observe the keys around and see whether something is stucked beneath them. You can use a little air blower or something like a toothpicker to clear stuff under the keys. If you can connect another keyboard to your laptop, you can try that too.
I heard about some program may change the key code of the keyboard so you actually may need to use other keys to enter that character. I hope that is not the case.
If nothing found with the keyboard, you can try to log in with the administrator's account which was created when you install your Windows 2000 and reset the password of the user account you are using. Steps are described in the following document. http://support.microsoft.com/kb/258289
You may also boot with your recovery CD and see whether you can get through the login stuff or reinstall the Operating System. As long as you don't repartition or format your data partition your data should be there still.
Shut down and restart,your computer . At the Dell logo screen, tap on the F8 key slowly a couple of times. Using your up or down arrow key select safe mode and hit enter. Hit enter again. You would see a adminstrator account , login using the same.
1. click start
2. Control panel>user account
3. Change the password of your account and restart your computer.
if keys not working means , try to service ur keypads... the service guy might change the keypad ic... it wil cost less only... without rectifying the keypad u cannot unlock.
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
My first solution for you would be, press the key Fn at the bottom left side of the keyboard and and the key on the top right hand side called ""num lik"" or ""scroll"". First hold the FN key down and then press only do not hold the num lik key.
Please tell me if you need a better explanation because I think I did not explained myself very clear.
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual. ***using the keylock *** Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad. To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears. The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
For the 6.0 gig phones, the manual explains in the handset set-up how to turn the keypad beep on and off. I rather like it as it serves as an audible indicator that the key was hit. Otherwise it is possible to have missed a digit. Of course, you can see the number on the display, but who looks?
