Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Canon EOS 300D Power On
I have fully charged the battery; when inserted into the camera and I turn the switch to the ON position, the camers does not come on.
  • 1 more comment
  • TnDV Jan 01, 2008
    Thanks for the reply. Tried this, but it did not fix the problem.
  • Anonymous Jan 14, 2008
    2 days after Christmas my camera just stopped turning on. It had been very tempermental before that for about a month. When trying to press the button to take pictures the word error would pop up on the screen and it wouldn't shoot. It suddenly went dead and have had no success after trying repeatedly to re-install the lens and charge the battery. I noticed a small disc type battery along the top side of the battery housing and wonder if this could have any effect? Help! The model # is DS6041 6.1 MP and I've had it for exactly 4 years.
  • Anonymous Feb 04, 2008
    I have the same problem and have used new battery, new 3v clock battery and cleaned contacts. Have dismantled camera to a point where I need to know how to release the top outer case. It is held at the top centre of the lenz aperture. Do I need to dismantle the inner lenz section to release a screw inside?
I am having the same problem. i, too, have had my camera for 4 years. and my model # is also DS6041. maybe they just make these cameras to only last 4 years :/ let me know if you are able to fix yours!
Posted on Jan 28, 2008
Re attach the lens. Sometimes they don't sit right and cause this.
Posted on Dec 31, 2007
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
Im getting an Error 99 on my EOS-300D Digital Camera when I turn off my YN 465 Speedlite flash gun (still mounted) and then I start shooting manually without the flash. Help please, its a bit annoying, but...
To fix this err99 issue, do the following
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera.
If it appears again, then proceed to next steps 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera.
If you still get the error you should send your product to canon for servicing.
Apr 15, 2010 | Canon Digital Rebel / EOS-300D Digital...
Canon 300d flash won't fire. Pops up ok but display just reads "busy" and camera locks up. Must turn on/off to get camera working. External flash works ok.
This may sound obvious, but have you tried to make surer the battery is fully charged and then see'ing if it still does this? The reason I suggest this is that I had a similar problem and when I fully charged the battery this problem went away. I tend to keep an extra battery (fully charged) plus the charger on hand at all times.
Dec 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
My EOS 300d is not recognized by computer
have you tried to change the USB cable, or USB plug?
if did not work, try uninstalling the drivers & reinstaling them again (also update the firmware of you camera)
hope this will work
Aug 21, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
I have Canon EOS 300D digital Rebel. I have had intermittent problem with the camera display screen going blank even though I put a freshly charged battery in. Usually I can take a couple pictures then the...
Strange, intermittent problems with the EOS Digital Rebels can be caused by a defective shutter release switch. We charge about $85 to replace it.
Nov 12, 2008 | Canon Cameras
Power Problem??? - Maybe Battery Related or On/Off Switch
Intermittent problems are often caused by the door switches - the battery door and card door both cause switches to activate. If it's been dropped on a corner, or the doors aren't closing completely, it'll not come on at all. Squeeze the area around those 2 doors to see if it comes on. If not, there's a loose connection inside that'll have to be opened up.
Jun 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
NO POWER
I would have to agree sounds like a motor or gear that the motor turns.
Dec 10, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS-300D not seen by computer/not turning on
Heat and batteries - maybe Try another battery Remove camera software from computer and put the disk in the box. Plug camera in switch it on and set it to upload mode Windows should find it as a new drive or[XP/2000/ME] will put up camera/scanner wizard.
Aug 06, 2007 | Canon Digital Rebel / EOS-300D Digital...
No power
Canon customer support with this. Camera to be replaced or a discount on a new one -depends on the age
May 04, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
235 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
