This is an entirely hardware issue......Please immediately visit any nearest service centre...
Step on it with the heel of your 6"pump
If you feel like recycling your camera contact me at critical1 (at) hotmail (dot) com
Thanks
critical1
When the power is switched on the lens does not come out. The screen reads ZOOM ERROR.
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
when the power is switched onthe lens comes out and the sign on the screen reads, switch power off and on again, when i do this the lens does not retract even though the power is off.
when the power is switched on the lens comes out , a sign appears, turn power off and on again, the lens does not retract, even when the power is off,
Same problem here the lens wont retract but a little bit, but to add i get a message lense error and the camera switches off. what goes with this anyone know.. its my sons camera, hes great with it and enjoys pic taking at his age of 17. IM SICK, I got it for his birthday and he saved no reciept or packaging.. HELP.. any camera buff there that may know a solution that i may do other than try to take it into a shop and have them rip me to tell me they cant fix it..
MOM IN NEED OF CAMERA HELP
me too only the red on light flashes thats it!
My lens is stuck; it doesnt get out. I received the message turn the power off and on again; I try and try on and off again but the lens keeps stuck.
