Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Panasonic projection tv
Pt-61lcx65 panasonic tv issues with power light is flashing red than shuts off
  • moralesg5 Oct 01, 2008
    tv would not turn on, green light blinking makes a ringing sound and then light change to red .
Call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Posted on Jan 03, 2008
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
TV won't turn on when push power button red light flashes
You can unplug the tv for 1 minute and then plug it back in since you have a red light you know it is getting power, also don't plug it into a surge protector when trying this. If the tv still has a flashing red light a service center will need to repair the tv, replacing more than likely the power supply or small signal board.
May 07, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I have a Panasonic PT61LCX65 that keeps shutting itself off. The lamp light blinks 3 times. Is it time to change the lamp? Thanks for your help.
Its not the lamp thats faulty but I think its the ballast(lamp's power supply). 3 blinks indicates that there is something wrong with the power supply to the lamp. If you have prior experience in electronics then you may wanna get a service manual to check/troubleshoot this issue.
http://www.tradebit.com/filedetail.php/9186960-panasonic-pt-44lcx65-pt-52lcx65-pt-61lcx65-service
Dec 05, 2009 | Panasonic Televison & Video
Pt-44lcx65
That seems it might be an issue with your ballast. With time this could cause the picture to go away, discountdashmerchantdotcom
Jul 26, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Reset tv timer pt-61lcx65 after lamp installation
MAKE SURE LAMP DOOR IS COMPLETELY CLOSED,THATS WHY POWER LIGHT FLASHES YELLOW
Jan 10, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic TV
Good Day,christie511;
It sounds like the lamp is in need of replacement. You could call a service company to replace the lamp, but it is so easy to replace the lamp ones self. So, call Panasonic and order the lamp, they will send to your home with instructions.
Three screws and your home free!
Good Luck, Big Irish.
Jul 08, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Most likely the lamp will correct this issue.
Apr 08, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
