Question about GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave 2 years old
Noisey operation that sounds like fan unbalace Can I repair?
  • Anonymous Dec 28, 2007
    Experienced sqeaky noise for several weeks, sounds like coming from behind the control panel area.  Today the microwave power at all.
    Problem Solver:
  • 19 Answers
Unplug the microwave first then pull the cover off the top front of the microwave with 2 philipshead screws, the unbolt the control panel with the one screw. let it hang down the you should be able to see tha fan.
Posted on Dec 30, 2007
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
GE Spacemaker shorting
From your description the cooling fan is not running, causes! open motor winding, seized motor, or defective door switch, you will need somebody to assess
Jul 19, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My 3 1/2 year old ge spacemaker over the oven microwave with vent fan has stopped rotating inside.
Did the cooktop lights recently fail?
If so, then the problem is probably on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but no head
I have a model number MCD1311ST. The timer seems to be operating however there is no sound and it is not heating or operating.
Jun 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sorry Seanna, but I have been getting a lot of problems with GE microwaves. You can call customer care at 800-432-2737, but out-of-warranty repairs are very expensive. Sounds like your problem may be door latch circuitry which requires service. If your unit is old, consider replacing it as prices are very reasonable.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Gear that rurns turntable very noisey
it may be the fan/fan cover assembly or it may also be the magnatron, after a while of use, before faulting the plates inside dislodge and can rattle around while in use.
Nov 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave model #JVM1650SH
Allways unplug when your working inside a microwave, you will most likely have to replace the bulb again and also the fan, or anything else that is damaged, you will need to inspect the microwave for broken parts.
Il get you a few links to repair parts.
Sep 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
2 1/4 year old GE Spacemaker XL 1850 Microwave doesn't heat
Check this website:
It sounds like it is either the power diode, the high voltage capacitor or the magnetron. If it is the magnetron, it may not be worth fixing as these can cost well over $100.
Do you hear a buzzing sound?
Dec 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
118 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
