Question about Janome Memory Craft 4800QD
Janome memory craft 4900 qc
My machine was fine whilst I was doing free motion quilting. When I then went back to the standard set up, it then would sew a few stiches and then grind to a halt and flash up E5 Error. When switched on and off would sew then do it again.
SOURCE: Janome Memory Craft 4900 QC
its the sensor on the bobinwinder who are loose. If you are handy. you can remove the top cover of the machine.
And on the left side of the bobinwinder you will find a micro switch. Probably you have to tighten the screw on it..
Posted on Feb 20, 2008
  • 41 Answers
Hi Susan,
You're absolutely correct, you'll need to either drop the feed dogs (lever generally located near the bobbin case or on the outside base of machine) or cover the feed dogs with a plate (many machines have this included).
Then... you'll need to lower the presser foot - when you lower it, it should NOT touch the bed of the machine but sit slightly raised off the fabric surface. As you stitch the presser foot will lower onto the fabric to hold it taught as the needle penetrates.
Oddly enough it's easier to achieve smooth stitches when sewing at a faster speed, but begin by stitching fairly slowly until you get a feel for free-motion stitching. You'll be doing all the guiding and it may feel a bit strange and uncontrolled at first.
Position yourself at your machine so that when your hands on your fabric/bed of machine, your shoulders are relaxed (not all hunched up) and your elbows are slightly higher than the bed of the machine.
You'll want to stitch in a side-to-side or back and forth motion (as opposed to trying to turn the fabric.
Best of luck with this technique. Once you're comfortable with it, you're sure to enjoy the freedom of creating!
Happy sewing,
Kim & Linnette
Posted on Jul 31, 2008
  • 21 Answers
SOURCE: janome 4900 sensor problem?
Maybe the bobbin winder is in the the on position. Push it to the off position.
Posted on Feb 11, 2010
  • 22 Answers
SOURCE: Janome 1600P quilting free motion sewes fine for a
Please ensure that you are uing the correct size needle for your that you are using. are you using a straight stitch needle plate. Please let me know what size thread and needle you are using
Posted on May 03, 2010
SOURCE: where can I purchase an instruction manual ,
try janome website for the walking & embroidery feet & manual
try these sites for manuals also
(pdf) manuals
Posted on Jul 31, 2010
SOURCE: I have an older Janome
The janome feet are interchangeable
Posted on Sep 15, 2010
0 characters
1 Points
Will a memory craft 4000 work without a foot pedal
Most machines require some sort of foot or knee pedal. There are, of course, treadle machines that you actually "pump" with your feet. There are also hand-crank machines available. Some of the newer machines that have a free motion capability can be set to stitch only when the fabric is moved under the lens, however, that is probably best only for free motion quilting and not for actually stitching seams, etc.
If your machine is lacking the foot pedal, check to see if a replacement can be found. Frequently, a sewing repair shop can either locate a generic or wire one for your machine.
Here's a manual for your machine:
Feb 25, 2016 | Janome Memory Craft 4000 Sewing Machine
My memory craft 350e won't keep the tension tight. What can I do to fix this? Please help.
Balancing Thread Tension - Janome MEMORY CRAFT ... > ... > MEMORY CRAFT 4900 QC > User manual
Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
Sep 19, 2015 | Sewing Machines
I want a longer straight stitch (mine only goes up to 5) on Janome MC 4900, to mimic hand quilting look.
There are several models of machines that do a longer stitch, usually called a basting stitch. Unfortunately, your machine does not have this function. If you are looking for a machine that will give you a hand quilted look, the Baby Lock Sashiko can give you that, though it doesn't do anything else.
Feb 26, 2014 | Janome Memory Craft 4900QC Mechanical...
Bobbin thread is not being picked up when I free motion quilt
Duh. It was the breaker. Always check the breaker ...especially around Xmas!
Dec 04, 2013 | Janome Memory Craft 9000 Computerized...
I have a Janome 6500 Memory Craft and I'm having problems with the thread tension while free motion quilting. No matter what the setting, the bobbin thread keeps popping up on the quilt top! I've only had...
Check this in your manual. I think when you do free motion you have the feed dogs (toothed things the rise up and pull the fabric under the presser foot) locked down but you still have to have the presser foot lowered. When the presser foot is locked in the up position, the tension on the bobbin thread is released.
Nov 05, 2013 | Sewing Machines
I was doing some free motion quilting & the bobbin thread started to loop, the machine shuders & the 'stop for safety' sign has come on I've cleaned out the bobbin casing, re-threaded...
Good day to you!!!
Have you try to change the needle??It maybe damage/bent...
If you are done doing it please also try to oil the moving parts...and reboot...
Please do have a comment if the solution is still unsolve.
Thank you..
Jul 27, 2011 | Janome Memory Craft 4900QC Mechanical...
I cannot get the feed dogs to come back up on my janome memory 8000 after putting them down to free motion quilt.
Flick the switch to raise the feeddogs then rotate the handwheel one full revolution to re-engage the cam...voila
Mar 25, 2010 | Janome Memory Craft 5700
Feb 12, 2008 | Janome Memory Craft 4800QD
Sewing Machines Logo
630 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
