To display Aero effects such as transparency in Windows 7/Vista, follow these steps:1. Click on Start menu.
2. Type the following text into the Start Search box: Aero
3. Click on a search result listing under Control Panel group that named as the following:
Find and fix problems with transparency and other visual effects.Trick: If you don't see "Find and fix problems with transparency and other visual effects" in the search results, click on
Control Panel to see all Aero related items in
Control Panel.
4. An "Aero - Troubleshoot computer problems" wizard dialog will appear. Click on
Next button.
5. The troubleshooting wizard will try to detect any problem by running a
series of checks against various components required to make Aero works
and running, such as video memory, Desktop Windows Manager (DWM)
service, color depth, theme, power settings and etc. At the end of the
analysis, the wizard will attempt to fix the issues related to Aero
service and restart the Aero feature.
Tip: If there is still items that are marked with red cross which
indicates is the problems that prevent Aero from working properly, fix
the issues and then rerun the "Find and fix problems with transparency
and other visual effects" troubleshooting wizard again.
Tip: To create a shortcut to 'Find and fix problems with transparency
and other visual effects', right click on it on search results, and then
click on
Open file location. On the "All Tasks" window opened, right click on
Find and fix problems with transparency and other visual effects again, and select
Create Shortcut to place the shortcut on desktop.
Hope this help. Goodluck!
