Question about Toshiba 44NHM84 44" TV
Won't Power Up
I can hear a loud 'crackling noise during start up - it sounds like it is trying to start but the bulb never turns on...after about 15 seconds the tv shuts off.
  • 1 more comment
  • Anonymous Jan 21, 2008
    Same here, Operation lamp flashes green for thirty seconds, then back to red. Sounds like it wants to start up, but nothing.
  • Jay16 Apr 26, 2008
    I actually got mine to work for about 30 seconds after this problem started then it turned off and I have yet to get it to work again.
  • Anonymous May 26, 2008
    same problem
I had this problem. Turned out the lamp life was over; when I removed the lamp from the tv, it was cracked. These lamps don't last long. We just replaced ours two years ago.
Posted on Sep 11, 2009
Pretty sure your bulb has blown
Posted on Oct 24, 2008
Have a 1 year old Delonghi oil heater and has starting to make loud crackling noises when hearing up for about 5 mins.
The sound you are hearing is the metal and the oil inside expanding. When you heat metals they expand. When it cools it shrinks. I would imagine that when you turn this off it is also making these noises but you are not there to hear them like you are when you turn it on.
Sep 23, 2014 | DeLonghi Heating & Cooling
When i turn the volume up to(17-20) my sound cuts out and my speakers make a cracklin noise.i have bought new speakers and rechecked all wires.my speakers are rated at 50 watts rms and my stereo pumps out...
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Car Audio & Video
No video but sound
its the bulbs and or soder connections loose needs resoldered. mine was a 60" and cost 893.00 to fix it.
Aug 18, 2014 | Televison & Video
I have an RCA Scenium DLP 50 TV. The TV started making a loud noise (like a computer fan) going out. The noise would go away when we powered off the unit and the bulb shut off. Eventually there was no...
yes ... you could have a color wheel problem.. this set get color from a spinning wheel called a color wheel.. when you unplug this and plug this back in you should hear a whining motor sound. During the "bootup" sequence this motor spins this wheel to test to see if it reaches speed. This is a motor that moves and anything that moves eventally dos not. i see this problem often in the shop and if it is the problem there not all that difficult repair. the hardest part is finding the color wheel
Oct 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
MY AKAI 50" DLP MAKES A LOUD RATTLING NOISE LIKE WHEN U SHAKE A LIGHT BULB THAT'S BLOWN OUT AND NEVER POWERS ON
Hi,it could be that the filement inside the bulb shattered and that's why you hear that rattling noise.But it could also be the color wheel which is a disc looking that has a gamma of colors and spins and very high rpm.When its bad or shattered you will hear a high pitch sound or crackling sound.I will recommend to take out the lamp and look at it to see if its blown,if its not the next step will be to take a look at the color wheel.Here's how : http://guides.fixyourdlp.com/samsung/bp96-01579a.php Good luck and God bless your house!
Jan 05, 2010 | Akai PT50DL24 Television
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Mysterious car noise
Check the oil first, if it is low it will cause a host of noises in the engine.
It sounds like that may be the problem you have
Nov 22, 2008 | 2005 Honda Civic
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Toshiba 44NHM84 44" TV Logo
338 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
