Maytag PYE4500AY Gas Dryer
Problem for Maytag PYE4500AY Gas Dryer
Install dyer belt MAYTAG
By kids9501 on Oct 15, 2009
HOW TO install dyer belt MAYTAG
Solution #1
posted on Oct 15, 2009
Not Rated)
tbirdfan1
Rank: Guru
Rating: 90%, 1072 votes
Hello there
Here is a detailed instruction for you ok
  1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
  2. Replace the Belt
  3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
    With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
  4. not too hard
  5. hope this is verry helpful for you
  6. Best regards MIke
Was this helpful?
Yes
No
Popular Solutions for Maytag PYE4500AY Gas Dryer
Questions and Unsolved Problems for Maytag PYE4500AY Gas Dryer
Do you recommend Maytag PYE4500AY Gas Dryer?
Answer
Answer
i am looking for a instruction manual for a Candy cc2039x tumble condensor dryer
Answer
Zannusi Condenser Dryer TC482W - How do I fit a new belt. Not sure what to remove to get to the... (More)
Answer
my whirlpool clothes dryer won't start
Answer
lost the instuctions for lp gas conversion kit
Answer
Have a frigidire FER34IACO and has a squeak when running, belt is fine. Think it is the tension... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , TX
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
