Texas Instruments TI-89 Calculator
Problem for Texas Instruments TI-89 Calculator
In the programs I have made when I use the Request
By pcross533 on Oct 15, 2009
In the programs I have made when I use the Request enter a integer, I always have to press the alpha button before entering a # in the field when running the program, is their a way to program a request which does this with out having to push the alpha button?
Solution #1
posted on Nov 02, 2009
Not Rated)
k24674
Rank: Guru  Office Equipment  Expert
Rating: 87%, 679 votes
The syntax of the command is as follows
:Request Message, VarName
where Message is a character string containing the message that will be displayed as a prompt, and VarName is the name of the string variable where the input will be stored.
If you want to input a numerical value you must convert it from character string to a numerical value (I know, it is like splitting hair but string 123456 is not the same as number 123456)
You convert from string to numerical value with the expr() command.
Exemple:
:Request "Value of a? ", s
:expr(s) --> a
That should do it.
Hope it helps.
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-89
Questions and Unsolved Problems for Texas Instruments TI-89
Do you recommend Texas Instruments TI-89 Calculator?
Answer
Answer
There is a line in the screen where no pixels are showing, is this fixable? - it is across the whole... (More)
Answer
If I try to make any graph besides a scatter plot, it locks up and it I haven't been able to get it... (More)
Answer
Half of the screen is black and half is well-lit. Editing the contrast results in one side of the... (More)
Answer
answer was tan-1(y)=x+@19 What does @19 mean?
Answer
when i installed the initial batteries, the calculator still had a blank screen. i adjusted the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Texas Instruments TI-89...:
Top Calculator Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
