GE TFX22ZR side by side. the ice maker is not making ice. there is water being dispensed. recently had a build up of ice... is there a reset button or could the build up have frozen something else?
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze.You can take the water
line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting
flow.
Was this helpful?
Yes
No
Popular Solutions for GE Side by Side Refrigerator
My GE side by side is four years old. Lately the freezer has stopped working and the meat is...
(More)
My GE side by side is four years old. Lately the freezer has stopped working and the meat is defrosting. If I unplug the unit, then plug it back in, it starts working again. Also, I have having another problem. The ice despenser is not working. The tongs that rotate the the ice out is just makes a humming sound and will not rotate on it own.
one year old GE side by side freezer works erratic.seems to defrost and then freeze then defrost...
(More)
one year old GE side by side freezer works erratic.seems to defrost and then freeze then defrost again.
