Samsung Digimax S500 Digital Camera
Problem for Samsung Digimax S500 Digital Camera
Hi, my camera went out of battery and the lens was
By chary12 on Oct 15, 2009
Hi, my camera went out of battery and the lens was out. Now I put the battery and it tuns on, the lensdoesnt move and then makes 3 beeps and shuts down, and it fell also. It was a present and I dont want to buy aother camera. Do you have a customer support so I ca send it (if the problem can not b solved).
Best Solution
posted on Oct 15, 2009
Very Helpful)
StephanSA
Rank: Guru  Cameras & Camcorders  Expert
Rating: 93%, 188 votes
Hello
Fixya does not operate a customer support so you will have to contact Samsung customer support. Send me your location and I will send you the contact details needed.
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Stephan
Comments:
Oct 15, 2009
- It's a pleasure.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" This wa great, instant answer I can not believe it, Thanks you so much!!!! " - chary12
Solution #2
posted on Oct 16, 2009
Somewhat Helpful)
KINKY130
Rank: Master  Cameras & Camcorders  Expert
Rating: 85%, 5 votes
FAQ HELP AT THIS LINK http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=0&AT_ID=104758&PROD_SUB_ID=0&PROD_ID=1148
HOPE IT HELPS!!!!
Was this helpful?
Yes
No
Solution #3
posted on Nov 26, 2009
Not Rated)
MrNutz
Rank: Guide  Cameras & Camcorders  Expert
Rating: 96%, 17 votes
It may help to install not only new, but high power ALKALINE batteries in the camera, then trying turning it on and off.
Was this helpful?
Yes
No
Popular Solutions for Samsung Digimax S500 Digital
Questions and Unsolved Problems for Samsung Digimax S500 Digital
Do you recommend Samsung Digimax S500 Digital Camera?
Answer
Answer
My camera lens is stuck. I turned it on, it ran out of battery, it turned off, the lens stayed open,... (More)
Answer
Camera will not turn on and beeps even though the batteries are fully charged
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung Digimax S500 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 904
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
