Panasonic CT-32SL14 32" TV
Problem for Panasonic CT-32SL14 32" TV
I have an horizontal white line in a black screen
By molaybusines on Oct 15, 2009
i have an horizontal white line in a black screen. i have an idea that could be the vertical modul but have no electrical schema to identify the capacitors or other componenets
Solution #1
posted on Oct 15, 2009
Not Rated)
rusty_etech
Rank: Guru  Televisions & Videos  Expert
Rating: 91%, 118 votes
You can usually find the bad caps with an ESR meter. There are only 3 or 4 capacitors in that circuit. Also, if you have completely lost vertical deflection you might want to replace the vertical ic. I always make it a habit to change the caps regardless. They are pretty cheap.
Was this helpful?
Yes
No
Popular Solutions for Panasonic CT-32SL14 32" TV
Questions and Unsolved Problems for Panasonic CT-32SL14 32" TV
Do you recommend Panasonic CT-32SL14 32" TV?
Answer
Answer
When I turned it on, it immediately lost power and I haven't been able to turn it on since
Answer
I cannot get channel 5 on my dvd player after tuning the tv All the other channels are ok
Answer
need a 4 diget set up code for a panasonic tv
Answer
i need diagram electric for panasonic tv CT-F2131M thank´s for helpme
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic CT-32SL14 32" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
