Question about Sony MHC-NX3AV Shelf System
Push power / protect Sony MHC-NX3AV
HI, my Sony MHC-NX3AV has a problem. It doesn't work as common, when I switch it on on display appears "push power/ protect". I've tried to do what is written on his technical guide but, it still has problem.
Can u help me?
ps- i've tried also to reset it completely as said on his guide but when I switch on again... he doesn't work :(
What can i do?
Thank for your support.
Lalla
  • 1 more comment
  • Nitant Oct 27, 2008
    Same issue, system seems to work fine, but just gives this error.
  • eashley Nov 07, 2008
    I have exactly the same problem, have tried the factory reset detailled in the guide, but no good. Tried leaving it unplugged in a dark room to see if that helped the little Sony gremlins inside, but nothing.
  • Anonymous Apr 11, 2009
    push,power potect
SOURCE: protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Posted on Oct 27, 2008
Luis2584
  • 7 Answers
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Posted on Dec 19, 2008
SOURCE: sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Posted on Feb 11, 2009
  • 4 Answers
SOURCE: Sony MHC-NX3AV wont let me change cds. It just
I had a similar problem, but this required a sony representative to fix it. I suspect that the track system the CD elevator uses has come out of place. Unless you know the internal workings of the machine, I would not suggest attempting this by yourself. Needless to say, damage to yourself or the machine could result.
See if you are under warranty and contact sony direct. This would be fixed for free, if you are, but it may mean being without your machine for a week or two.
Posted on Aug 07, 2009
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
Power protect
is' protect 'appears on display?.remove speakers & check again.if then set work without error check speakers & cable. protect appears again there is a problem with power amp module.
Jun 14, 2011 | Sony MHC-RG40 CD Shelf System
Sir my sony stereo system showing "protect push power" how i troubleshoot the problem please replay fast
Protect Push Power on a Sony is telling you that you have an output short circuit and to turn off the player to prevent further damage.
Check the speaker cables for connection fault. If all is OK it means you have a blown STK Amplifier Chip. Will cost you about 20$ plus labor.
Apr 30, 2011 | Sony MHC-NX3AV Shelf System
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Whenever i turn on my sony MHC-VX333 mini hi fi it flashes the message "push power protect"
when it display push power,this indicate an instruction to push the power button. please do so
May 17, 2010 | Electronics - Others
Sony Mhc GS100 want power up
Dan
Aug 19, 2009 | Sony Audio Players & Recorders
Sony MHC-NX3AV wont let me change cds. It just jams up ?
Jul 12, 2009 | Sony MHC-NX3AV Shelf System
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Protect and push power
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC if its works! if not that is the time you replace it, so it works normal again. Hope it may helps you...
Jun 08, 2009 | Sony MHC-GX450 CD Shelf System
Sony MHC-NX3AV Shelf System Logo
234 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
