Question about GE Kitchen Ranges
GE gas oven won't come on
I have a GE gas stove/oven model #JGSC12GEV1BG (best I can tell). The oven pilot is on but the oven will not come on. It worked fine Sunday, but will not light today. The burners on top work fine and the pilot will stay lit, but the "burner" just wont light up and get hot. Any ideas?
SOURCE:
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
SOURCE: gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Posted on Dec 14, 2008
MNfisherman
  • 11896 Answers
SOURCE: GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Posted on Jan 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
Maytag317
  • 1136 Answers
SOURCE: my stove will not ignite...but the burners do
There is no pilot. The oven has an electric ignitor to light the flame. This ignitor is very common repair.
You can remove the floor panel inside the oven and start the oven. Watch to see if the ignitor glows. Even if the ignitor glows, it should ignite the flame with in 30 seconds. They get weak and don't pull enough amps to open the gas valve.
I hope this helps you. please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
How do you light the pilot on a GE stove The top of the stove works
Hi, If this model has a standing pilot, use a lighter and put the flame to the back center next to the burner assembly. Most newer models have electric ignitors now. It is fastened to the burner assmbly on the laft side.
If this an electric ignitor, turn the oven on and see if the ignitor glows. These ignitors are a very common problem and will probavly need replaced.
Please let me know if I can assist youu further.
Vic
Jul 03, 2009 | GE JGRP17 Gas Single Oven
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
GE Spectra XL 44 Gas Oven Bottom Heating
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
Need info.......
i don't think that model has a pilot try the oven and see i think its electronic ignition
Mar 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
GE Profile JGB916
LP or natural? Are the valves set correctly for such and the regulator value changed if a different gas is used than what the manufacturer set the stove up as?
Good Luck...
Sep 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
62 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
