Get picture up on file manager go to send pictureis resized but trys to send but failing
Have you downloaded the MMS settings from you service provider?
If not, call them and they will send you the settings via a text msg, and give you a PIN to use when installing. When you receive the txt select SAVE or INSTALL when prompted input the PIN number.
MMS does not always work between networks.
Anyway to view PDF files you have to download PDF Reader (Download links given below) or send it to your Sony Ericson and install the application.As far as I know this PDF reader supports the following Models
Sony Ericsson k750i
Sony Ericsson W810i
Sony Ericsson k800
Sony Ericsson p990
Sometimes you might get a "Invalid Application" or "Operation Failed" error, in that case try to re install PDF reader application! As Sony Ericsson mobile phones support .Jar file extension,I have uploaded the PDF Jar file to different file hosting!
check this lick for SONY mobile softwares.--http://ptf.com/sony/sony+ericsson+c902+mobil+software+pdf+reader+java+free+downlod/
thanks for rating
Good luck
