You might want to try cleaning the cold water inlet screen. Turn the water off where the hose connects to the faucet. Disconnect the cold water hose at the washing machine, you will see a small screen inside the cold water connector on the washing machine. Use a very small screw driver or heavy needle and work the screen out of the inlet. If the screen is not dirty or plugged, you may need to replace the water switching valve. It is the valve assembly that the hot and cold water lines attach too in the back of the washer.
Good luck.
Regards
