Question about Acer LXA3706003 Notebook
Internet connexion I'm trying to connect to internet. I took the connexion from the modem, but it always says i'm disconnected. do i have to program something? I went in "d?marrer" and "panneau de configuration" than "propri?t?s de internet", but i don't really know what to look for? thanks
  • 32 Answers
Hello marieclaude,
How exactly are you trying to connect? via modem, if that is the case the "disconnected" warning or notice you are seeing is probably the LAN line. That is the other port that looks like a telephone jack, but is a little bigger.
If you can get online and there is no problem except that annoying notice you can; go to control panel, double click 'network connections', right click the 'Local Area Connection' next to it should read - disconnected, after right click - select 'disable'.
Now you won't get that message or that box with the red x in the corner anymore. If you ever do need to connect through that port in the future, you will have to go back to control panel, follow same steps and then select - 'enable'.
Regards,
-Chester
Posted on Dec 27, 2007
Can't connect to xbox live
Are all the connexions connected where they should be? Is your console has access to internet (wire connected if internet by wire from modem) or wireless internet on?
Aug 31, 2011 | Video Game Consoles & Games
My internet connection never runs constantly. i always get disconnected after using it for a minute or two and then my router again tries to establish a internet connection.after the connection has been...
1. Disconnect the router from the modem.
2. Reset the modem.
3. Connect your computer directly on the modem.
4. Check if the wired connection is OK (for longer time).
5. If not, check/replace the filter splitter, if you have one.
6. If still having problems: Call your ISP to check your status.
7. When the problem is solved, connect the router to the modem.
8. Reset both router and modem.
9. Recheck the connection.
Aug 13, 2011 | Linksys Wireless-G Broadband Router
Why can't I connect to the internet via my router but when I connect directly to the modem, I have internet access
If you don't reset the modem after connecting the router, the modem is still trying to send data to the MAC address of your PCs network card.
You need to disconnect power from everything, then power up the router first.
Once the LEDs on the router settle down, power up the modem.
Once the modem's LEDs have settled down, power up the computer.
You should now be able to access the internet through the router.
The only time this won't resolve the issue is if the PPPoE negotiation is being done by the PC and not programmed into the modem itself.
This is almost unheard of with modern DSL and ADSL modems today, but if that is the issue, you will need to contact your ISP for the information you will need to program the router to do the PPPoE login through the modem and reconfigure the computer to not do the PPPoE authentication any more.
Jul 21, 2011 | Linksys Wireless-G WRT54G Router
Will not connect to internet
Has it worked in the past, and connected to the internet through the same modem? When I had one of these any time the Internet Connection would hickup I'd have to restart everything in the right sequence. As long as your connections are correct, shut down the Linksys router, by removing the power cord, as well as shutting down your modem. Then restart your modem first and wait until it's all set and ready to go. Then restart your Linksys afterwards so it can find the proper IP Address assigned to your modem. It should connect to the Internet, but you always have to restart the modem first while the Linksys is still off. Also make sure the power is disconnected from your Linksys for at least 30 seconds before powering it back up.
Nov 28, 2010 | Linksys Wireless-G WRT54G Router
I am unable to use the bluetooth app in my laptop..the moment i open, it shows error 797 a connection to the remote access server was not made because the modem was not found.......please help me..........
This is for GPRS connection
You must have from your network provider: the internet access point name, your user name and password.
Download and unzip the attached file in a folder on your desktop
1- Disconnect the device from your desktop
2- On the Activesync icon on your desktop, open "Connection Settings". Uncheck "Allow USB Connection".
3- On your device: Go to "Beam" (in Settings/Connections), and uncheck "Receive all Incoming beams".
4- Then in Programs, click on "Wireless Modem". With the Connection type on USB, click on "Start".
5- Now, connect your device to the desktop. The "Found New Hardware Wizard" starts on your desktop. Click "Install from a specific location", then "Don't search. I will choose...", then click on "Modems", and "Have Disk..." and go to the folder where you unzipped the attached file.
The HTC USB Modem will be shown in the compatible hardware: click to install. Continue if you receive the alert of the software not passing the Windows XP compatibility test (Continue anyway). Finish.
6- Now, in Control Panel of your desktop, open "Phone and Modem Options". Select the "HTC USB Modem" and click on "Properties". In the "Advanced" tab type for "Extra initialization commands":
AT+CGDCONT=1,"IP","xxx","",0,0
where xxx is your internet access point.
Click OK to finish.
7- On your device (always open in the Wireless Modem program), click on Tools/Options. Check the Preset GPRS connections and write in the APN, your network provider internet access point.
8- Finally, on your desktop, go to "Network Connections" and click "Create a new connection". Choose "Connect to the internet", then "Set up my connection manually". Click "Connect using a dial-up modem", then give a name to your ISP. In phone number type *99#. Get username and password from your network provider.
Better keep a shortcut of this connection on your desktop for quick access.
Each time you want to use your device as a modem:
Disconnect your device
Disable Activesync from your desktop by unchecking the "Allow USB connection"
Open Wireless Modem on your device and push on Start (with the Connection Type on USB)
Connect your device, then dial from your desktop using the shortcut you created
PS: Remember to enable Activesync once you've finished.
Nov 16, 2010 | Computers & Internet
My belkin N router always disconnects on the internet. im sure its not a modem issue coz when i try to restart my router its connected again to the internet. my belkin router model is f5d8233-4v3....
Disconnections are generally relative to the Internet Provider and Speed. If the speed drops, the router can disconnect and reboots. Just make certain you always update all drivers and especially if you are in Windows, keep up with current updates. Check your device drivers and do update from there also.
Feb 07, 2018 | Belkin N Wireless Modem-Router F5D8633au4A
Internet always disconnect
Is it disconnecting through the router or modem?
If it getting disconnected through the modem, then first check whether it disconnects through the modem.
connect the computer directly to the modem and check whether it works properly or not?
If it is working properly through the modem then there must be a problem with the router.
try to upgrade the firmware of the router.
Click Here for more info about networking
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
Acitivity light is always off, cannot connect to the internet
Might want to try a new ethernet cable going from your modem to your computer- If that does not fix your problem then I would try connecting through USB.
Sep 28, 2008 | Arris SURFboard SB4200 Modem
Every time we try to use the internet it says unable to find server, if we unplug the ntl modem and plug it straight back in the internet connects how do we solve this
sounds like the internet connection is not setup to Ur modem. When u unplug it redetects the modem and connects. try uninstalling the modem from the control panel - system - device manager. keep the modem connected and reboot. U may have to use control panel - add/remove programs any programs the modem cd installed. on reboot use the modem cd only to get the driver and let windows control the modem.
May 26, 2008 | Computers & Internet
Wireless router
Make sure that the ehternet cable going from your modem is plugged into the slot on the router named internet.
Mar 30, 2008 | Computers & Internet
Acer LXA3706003 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
