Phillips matchline idtv 100hz digital scan tv
HI could anyone give me a bit of advice on repairing a problem on my tv symptoms are, one day i was watching it then it just switch off and the standby light was flashing on and off. I try disconnecting it from the power for a while then tried to turn it on, but just as it was supposed to turn on the standby light just started flashing again.
Please could anyone help?
  • Anonymous Dec 30, 2008
  • 4234 Answers
SOURCE: Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Posted on Mar 18, 2008
SOURCE: SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
The fault seems to be a fault in the line out put stage.
check connections in output stage. for poor joints.
Posted on Aug 16, 2008
SOURCE: SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
Posted on Nov 22, 2008
ladywinn
  • 5138 Answers
SOURCE: Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Posted on Dec 27, 2008
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Posted on Jan 10, 2009
I have a TV (Murphy 22883 idtv hd dvd) and no idea how to use component
I suggest you study the operation manuals and follow step by step.
Aug 13, 2012 | Toshiba REGZA 47HL167 TV
Our phillips tv 100hz digital scan 29pt9418/79 won't power up
Yes,it about 90% of the times,it the power supply board.U can look around the power supply board for puff up bulge capacitors,replaced these caps will get ur power back.10% it ur Tuner signal board.If find no defective caps in ur power supply board.Tries websites Shopjimmy.com.Ebay.com to buy ethier refurbish power or tuner boards for the replacement.
Apr 04, 2010 | Philips 26PF9966 26 in. LCD Television
NO PICTURE OR SOUND ON MY PHILLIPS MATCHLINE LCD TV 15PF9936 PLEASE HELP!!!!!!!!!!!!!!!!!!!
make sure it has power at the outlet,then suspect a blowed fuse or dioed or flyback,etc.
Feb 13, 2010 | Televison & Video
Rgb connection not working
check tv manual for native resolutions and verify settings on laptop also verify progressive scan or interlaced and verify they both match output input
May 08, 2009 | Televison & Video
Phillips SAA7130HL TV Tuner VISTA 64 BIT DRIVERS
well i had the same prob, so i downloaded drivermax, which I think is free.
drivermax scanned my computer and found all the drivers I needed including the vista philps tv tuner driver.
another way is to download iobit advanced system care which is an excellent free program and click the utilities button and then click drivers update. This should give you the philips driver as well.
hope this helps
it certainly worked for me
anyway you should be able to use the 32bit xp driver.
regards peter
Jan 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Phillips IDTV 100hz
Try to upgrade to the latest software. You can download the driver software from Philips's Website.
Jan 17, 2008 | Philips 50PF9431D Television
Televison & Video Logo
1,592 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
